11-02-2024 09:07 AM
My nest thermostat has lost connection. To my WiFi. Nothing has changed, I have worked through all of the troubleshooting tips, it sees the network but fails to connect when I put the password in.
11-02-2024 10:08 AM
That also happens when you connect via your phone also?
11-02-2024 10:19 AM
All other WiFi devices are working.
11-02-2024 10:28 AM
What is the answer? Does it connect via your phone?
What I was asking is, Does the thermostat connect to your phone Hotspot???
11-03-2024 12:37 AM
Sorry, I misunderstood. No, it won’t connect to my phone hotspot either. It can see all the networks available but fails to connect when I try each one.
11-03-2024 01:47 AM
That’s odd f you can see all the networks. I would suggest a factory reset to clear any gremlins, then with luck you should be able to connect.
11-03-2024 02:06 AM
I’ve done a factory reset too and still having the same problem.
11-03-2024 02:28 AM
Silly question perhaps, but how did you factory reset?
Which model thermostat do you have, and how old is the set?
11-03-2024 06:45 AM
On the actual thermostat, I followed the instructions on the help page. I have ended up speaking to google nest though and they are going to send me a new device as it seems to be a hardware fault rather than just a glitch. Thank you for your help though.
