10-21-2021 11:14 PM
Hi
we are moving house and as per the recommendation on this forum, I reset my thermostats to factory settings to erase all personal data. I had no issues with my upstairs/wired zone, but my downstairs thermostat (on a stand) lost its connection to its heat link. I tried resetting the heat link etc, but still only get the H71 error code. PLEASE HELP as I cannot leave it like this for the new owner.
Thanks
10-22-2021 02:21 AM
That's nice to hear the forum recommended you to move, very thoughtful!
Your thermostat might be an umatched pair, try, in Equipment or in the listing you can see ''Replacing Heat Link'' in the options.
You will need the entry key found by the left hand fixing screw, or on the cover by the screw of the Heat Link.
This may be your problem, worth trying that first.
10-25-2021 04:58 AM
Hi @Lourenbl,
Thanks for reaching out. I'll do my best to get this resolved for you. Can you tell me the color of the LED on your Heat Link?
Cristian
10-27-2021 05:07 AM
Just checking in. Do you still need assistance?
08-31-2022 09:17 PM
I also have a problem to get my nest to connect to the heat link, even turning my home router wifi off it can't connect to the heat link.
09-05-2022 07:03 AM
Hi @Lourenbl, @MAPZEUS, thanks for letting me know. I'm sorry to hear you're experiencing this issue, but we'll sort this out together. Let's start with a few questions:
What type of Nest thermostat do you have?
What is the color of your Heat Link's light?
How is the Heat Link being powered when you're trying to pair it?
What troubleshooting steps have you done before contacting us?
When was the thermostat installed?
When the unit was installed, did the display communicate with your Heat Link? If yes, how long after the installation did the issue occur?
Have you had any recent power cuts in your area? If yes, has the error persisted since this power cut?
Has there been any recent work done on your heating system?
What is the distance between the Heat Link and Nest thermostat? Are the Heat Link and display on the same floor?
09-07-2022 07:26 AM
Hi there. I'm just following up on our last message. Do you still need our help? Keep us posted.
09-09-2022 07:39 AM
Since I haven't heard from you in a while, I'll have to close this thread. Should anything else come up, please open another thread and we'll take it from there. Have a good one and stay safe!
