Nest thermostats: I do can control my temperature settings and set my eco mode, but no WiFi!
Hec
I try resetting the network by reboot the router, remove the thermostat from the nest app and restart the thermostat! I don’t see any network showing in the thermostat screen..
Without any WiFi the only way to control your Nest Thermostat is by using the Nest Thermostat display units user interface.  You mobile app will not work.
AC Cooling Wizard
Thanks for reaching out. I'm sorry for the delay. I just want to check if you manage to see the response above. Also, could you please share with us your Nest Thermostat power readouts? You can go to your thermostat Settings, then Technical Info.
Hi Hec,
 I just want to check if you're still encountering the issue. Please let me know as I'll be willing to assist you.
Hey Hec,
I'm just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns, as I'll be locking this thread in 24 hours.
