11-04-2024 02:38 PM
I had a nest that worked great but the battery needed replacing. When replacing it I broke something so I bought a replacement face of the same model - version 3 learning. This one won’t charge on the wall. I have to take it off the wall and charge externally. It also says it’s never strong enough to connect to the app so it’s always off line. Not sure why the second one doesn’t work like the first one
11-05-2024 07:56 AM
Where di you purchase the replacement display? Was it New or used?
11-05-2024 10:15 AM
My Nest stopped charging after they replaced my furnace and AC.... The power says not strong enough to connect to app or wi-fi.... I can take it down and charge it up and it works for a while then it drops again so I don't think it is charging on the wall. I haven't found a good test to see if it is actually charging on the wall.
11-07-2024 05:29 PM
Thank you for reaching out and sharing detailed information. I understand that you are encountering some charging issues with your Nest thermostat. I'm here to help you find a solution together.
To assist you further, please attempt the following questions:
In the interim, you may check the Nest thermostat's USB compatibility and charge for nearly an hour:
Micro-USB port
Mini-USB port
No USB port
Please keep me posted and let me know how it goes.
Warm regards,
Jeremy.
