01-23-2022 09:09 AM
3rd gen suddenly showed no power to Rh wire. Honeywell works just fine on the wall. And after heating people came to clean boiler I decided to put back on the nest. It worked fine but the battery was low so I removed it to charge and it decided to restart on it's own. When I reconnected it, it said once again now power to Rh. Now it's completely off the wall and still says no power to Rh. I can't even factory reset it. I can't get off the diagram / Tech info screen. Nothing about the nest is on the wall. Thanks.
01-24-2022 04:40 AM
You can use the USB port on the back of your Nest Learning Thermostat or Nest Thermostat E to charge it up when the battery is low.
01-24-2022 06:39 AM
Batter level is fine now. It’s stuck saying no Rh connected even off the wall and fully charged. I want to factory reset it but cannot get to that screen.
01-24-2022 09:52 AM
01-24-2022 12:36 PM
Ok thank you. I will try this and see if it will let me reinstall it from scratch.
01-25-2022 04:31 AM
Let us know if it worked.
