No heat from heater
Reinisland
Nest first gen does not turn on heat, only blower fan. A/C works fine.
Are you referring to the Nest Learning Thermostat 1st Gen or the newish Google Nest Thermsotat?
EdwardT
@Patrick_Caezza, thanks for the help!
@Reinisland, how's it going with your Nest Thermostat? Still need our help?
Edward
Jeran
Hey there Reinisland,
Do you have any more questions or need any additional help?
Thank you,
Jeran
EdwardT
Hi Reinisland,
Edward
