12-06-2021 03:47 PM
I am unable to get enough power to my nest thermostat. I have forced hot air and cooling with multiple zones. I original had a 3 wire (R,W and Y). I ran another 2 wire with it to my furnace zone control board. I tried using one wire as the C Wire and found a terminal on the zone board (from the transformer feeding the board 24v) that that was common to the R wire completing the circuit. The nest tells me not enough power. I tried adding the nest connect adapter with also no luck. The zone control board has a common terminal where the main furnace control board wires are feed into the zoning system, but this common is somehow isolated from my thermostat terminals. . Any other suggestions?
12-07-2021 08:59 AM
That’s about 1.A amps, should work fine in theory but I have seen cases in the past where it did not. Yes you can add a 24V AC 300-500ma and join with existing R and use the common of that transformer as the C (do not join it with the existing C you have coming out of your transformer).
12-07-2021 08:08 AM - edited 12-07-2021 08:10 AM
What’s the amperage of that 24V transformer? I assume you did not wire your C at the same location where your R was sourced, just making sure since you are saying “that that was common to the R wire completing the circuit”?
12-07-2021 08:44 AM
Thank you for your reply. The transformer feeding the board is 24v/40VA. I used this for the common wire. With a volt meter I get 24v between this and the R going up to my thermostat. Was also think maybe trying a plug in 24v/500ma transformer by the furnace and connect it to the common wire and R wire going up to the thermostat to this. Thoughts?
12-07-2021 08:59 AM
01-12-2022 05:35 AM
Can I buy one C-Wire power supply and power two separate thermostats by daisy chaining together??
Each thermostat control separate zones and are 8 feet from each other in height. Not being cheap, just lessening wiring in wall.
