08-04-2023 09:19 AM
Hi, my nest thermostat stopped working today. Before it died completely It showed fault code h72.
we then noticed there were no lights on the heat link, and pressing and holding the button for 20 secs does nothing either. We have come to the conclusion that there is a fault with the Heat Link, as it does not come on although there is power going to it. What can I try next? Any ideas?
Thanks in advance, Mag.
08-05-2023 05:28 AM - edited 08-05-2023 05:28 AM
There are some things you can check (see the "H2, H72 or H152" section):
https://support.google.com/googlenest/answer/9240096#thermostat_power&zippy=%2Ch-help-codes
If you're still experiencing issues after that, possibly the heat link has gone faulty.
08-05-2023 08:12 AM
Thank you very much David. I had done all the checks for the code H 72, but then the nest went blank. The lights on the heat link were off too. So I guessed the link was faulty.
I followed the next steps and choose to get a phone call, and was called in seconds. I am booked in with someone from Boxt, and hope to have the repair done very soon.
I very much appreciate your help, especially the tip in suggestion 3. To click other! Otherwise I would still be going round in circles..
Thanks again,
Mag. 😊
08-06-2023 04:10 AM
No problem, you're welcome!
08-08-2023 12:29 AM
08-08-2023 01:52 AM
Thank you I will do. Boxt are coming tomorrow morning, so I’ll let you know after their visit.
Mag 🙂
08-08-2023 01:59 AM
That's great. Keep us posted!
08-09-2023 08:59 AM
Thanks for all your help. Boxt engineer came and had the problem sorted in 15 minutes. Heating is up and running again. The heat link was faulty.
Thanks to Google Nest for the replacement heat link, with no charge. 😊
Mag4
08-10-2023 12:48 AM
Hi there @Mag4! I'm glad to hear that everything got sorted and your heating is up and running again. I'll have to close this thread now, but should anything else come up, please feel free to reach out any time. Have a wonderful day ahed, and stay safe!
