R to RC jumper 3 wire system
Csled
My old thermostat was wired with a W G R with a jumper to RC. When I run through the set up, it tells me to remove the jumper cable. So I did, but I’ve lost my ability to control the fan. Attaching a photo for reference. It’s a propane system.
EdwardT
Hi Csled,
Thanks for reaching out. I'm sorry to hear that you're having an issue with controlling your fan. You should still have an option to control it without having a jumper to the R terminals. Could you check the equipment tab on your Nest Thermostat to check if your Nest Thermostat is detecting your fan wire?
Edward
Hey Csled,
I wanted to check in and see if you managed to see Edward's post. Please let me know if you have any questions from here. I would be happy to assist, and make sure you are good to go.
Hey Csled,
