05-17-2022 06:30 PM
This is my wiring set up to thermostat. Red-r yellow to 1+ white to 1- blue to common. I kept the same except I put white to w1 and yellow to y1 cause there is no 1+ or 1- on google nest learning thermostat but it will not turn cooling or heating on.
05-17-2022 08:02 PM
Your system is not compatible with any of the Nest thermostats as it is using a proprietary interface.
05-18-2022 08:55 AM
Thank you for the reply
05-18-2022 09:21 AM
Will the ecobee smart thermostat work with this interface?
05-20-2022 12:30 AM
No
05-25-2022 01:16 PM
Thanks for visiting the community.
I'd like to jump in here and check if you've seen Patrick_Caezza's responses about your system's compatibility with the Nest thermostat.
Ryan
05-28-2022 03:15 PM
Ryan
05-29-2022 03:46 PM
Have a great day.
Ryan
