Trying to figure out if my heat-pump system is compatible with Nest
n0z0n3
Hello!
This is the thermostat wiring for my mother’s Kenmore heat pump system (about a year & a half old).
Will this work with the Nest? (Non-learning version)
6 REPLIES 6
MelbaDT
Hey n0z0n3,
Thanks for reaching out and for the photo.
Based on the wires of your current thermostat, it seems that you have a dual fuel system. Sometimes, this is also called a hybrid or packaged system which is a combination of a heat pump for primary heating and cooling, and a furnace (usually gas or oil) that provides a second and/or third stage of heating.
While this is compatible with our Nest thermostats, you will need to have a trained professional set up your thermostat. It’s important for a professional to assess the requirements for your specific dual fuel configuration since choosing incorrect options for a dual fuel system can result in damage to your system. Please contact a local pro.
Melba
Ryan_G
Hey n0z0n3,
Thanks for your help, Melba.
Ryan
n0z0n3
Thanks, Melba!
My mother's going to contact the company that installed her system, and talk to them about installing the Nest, if possible.
Ryan_G
Hey n0z0n3,
Thanks for the reply and we're sorry for the delay.
We're glad to hear it from you once a technician installed your Nest Thermostat.
I hope to hear from you soon.
Ryan
MelbaDT
It's us again — how's it going? Have you had a technician install a Nest thermostat already?
Melba
Ryan_G
Have a great day.
Ryan
