Was told to post a picture for compatibility for nest thermostat
irvinavitia
Was told to post a picture and see if it is compatible
7 REPLIES 7
Your systems appear to be a 2-stage cooling (Y and Y2). Your common, C, has a blue wire, the blower fan is G and has green wire, The heating W, has a white wire on it.  The R has a red wire.  Yellow wire in on Y, and brown wire is on Y2 which is stage 2 cooling.
MelbaDT
I appreciate your answer and thorough explanation, CoolingWizard.
irvinavitia, just to add to the response above, your system may work with any of our Nest thermostat devices. Wire it exactly like CoolingWizard suggested and  you'll be good to go.
Melba
MelbaDT
Hey irvinavitia,
Checking back in — we hope you got the answer you're looking for. Let us know if you have more questions in mind.
Melba
DUCKMAN100
Here is a picture
Ryan_G
Hi DUCKMAN100,
I think the picture is not included in your last reply. You could reply with this thread and click on the attachment icon to include a photo.
Thanks for your help, Melba.
Ryan
Hey DUCKMAN100,
I wanted to check in and see if you managed to see Ryan's post. Please let me know if you have any questions from here. I would be happy to assist, and make sure you are good to go.
Hey DUCKMAN100,
