Wi fi and battery off
Dearingt
General question. If my nest thermostat loses its wi fi connection while I am on vacation and the thermostat battery drains down as well - will the furnace and thermostat still work . I am fearful that I would return to a freezing house and burst water pipes.
David_K
Once the thermostat switches over to battery, it will have enough battery power to last a couple of hours. Then, it will completely shut down. It does try to make any necessary changes to its programming in an attempt to keep it running as long as possible, but once the battery dies it can no longer control your heating and cooling.
If you live in an area where power outages are frequent, or you are generally concerned about your Nest thermostat losing power, you should not rely on its battery life. Since it is only designed to operate for a short time on the built-in battery, usage on the battery is not meant for heavy or long-term use. If this is a concern for you but you still want to have a smart thermostat in your home you should consider investing in an Uninterruptable Power Supply (UPS) or generator that will ensure your peace of mind.
aatienza
Hey Dearingt,
Checking in — we hope you've got the answer you're looking for. Let us know if you have more questions in mind.
I appreciate the help, davidking.
Archie
EmersonB
@Dearingt, we wanted to follow up and see if you are still in need of any help. Please let us know if you are still having any concerns or questions from here, as we would be happy to take a closer look and assist you further.
I appreciate the help, davidking and Archie.
EmersonB
Hey Dearingt,
Just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, we would be happy to keep it open. If there's more we can do, just let us know.
