05-27-2023 11:37 AM
Have 4 wires connected to old carrier lipa edge thermostat wiring to it is. white wire to rs - . Yellow wire to rs+. Green wire to vg. Red wire to v+. Where should wires go on nest thermostat plate?
05-27-2023 03:05 PM - edited 05-27-2023 03:06 PM
What do you have is a manufactures digital proprietary thermostat. It communicates using data and not simply voltage. This is not compatible with a nest thermostat. The good news is, most of these systems. Can be converted to a conventional HVAC control system. You will need to hire a Nest Pro to investigate and advise if your system can be converted. If you have at least five conductors in the thermostat cable, you may have a chance to get converted to a nest smart thermostat.
AC Cooling Wizard
06-03-2023 10:42 AM
Hi Kev12n,
Thanks for reaching out to us. Your current thermostat has the non-standard labels of rs-, rs+, vg, and v+ which means that your system is proprietary.
Proprietary systems aren’t compatible with Google Nest Thermostats. However, some proprietary systems can be rewired by a pro installer to be compatible.
Let us know if that helps.
Zoe.
06-06-2023 10:50 AM - edited 06-06-2023 03:35 PM
@Kev12n, I wanted to check and see if you managed to see the information has been shared. Please let me know if you have any questions from here. I would be happy to assist and make sure you are good to go.
06-07-2023 11:36 AM
We haven't heard from you in a while, so we'll be locking this thread if there is no update within 24 hours. If you run into any more issues in the future, please feel free to create a new thread.
