12-26-2022 01:36 PM
Hello, I have the following configuration. I originally had a Trane thermostat. There are 2 jumpers in it that you can see (x2 to w2/1 and rc to r).
I have an all electric system. My aux heat doesn’t appear to be working (I can’t hear the furnace/compressor like I could with the trane). Is this wiring incorrect? Thanks for any help!
12-26-2022 02:12 PM
You dont use jumpers on the Nest.
Wiring looks correct.
You have to set up the Heat Pump Balance settings for when you want to switch over to Aux heat.
Or you can turn of balance settings and have a fixed outside temp that the system will shut off the heat pump and switch over to the all electric heat coils.
Read this about setting up the heat pump balance
12-26-2022 02:12 PM
12-26-2022 05:55 PM
Ok, thank you!
12-30-2022 06:48 PM
Snekxuens, checking in — we hope you've got the answer you're looking for. Let us know if you have more questions in mind.
I appreciate the help, Houptee.
Archie
12-30-2022 07:20 PM
I think I’m good now, thank you! 🙂
01-03-2023 02:20 PM
Hey Snekxuens,
Awesome! Let us know if you have other questions as I'll be locking the thread after 24 hours.
Archie
