fan does not run after a power outage
Juan4
The fan stopped working after a power outage. Fan is not running at all. The A/C unit is less than 6 years old.
8 REPLIES 8
Hello Juan,
Let us do some checking.
1. When you turn in the AC in cooling mode, does the blower fan come on?
2. When you put the system in Heating Mode does the blower fan come on?
3. when you put it in Cooling mode and go outside, is the outdoor unit running?
Sometimes. Power outage and the inrush of power when restored by the power company causes a low voltage the fan capacitor can get damaged.  Please report back your findings.
Juan4
Below the answer to your questions:
1) NO. The blower makes a click or sound that is being turn on but it does not blow any air.
2) No. Same thing it will start to smell of the heat of the resistance but no air blowing.
3) I can't check it is in the roof top and I do not have access at this time.
This sounds like the capacitor on the blower has failed.  You will need and HVAC technician to come check it out.
Juan4
Thank you Cooling Wizard
Online, Look up AC Cooling Wizard, in El Centro, CA and give a call, please.
EdwardT
@CoolingWizard, thanks for the help!
@Juan4, how's it going with your Nest Thermostat? Still need our help?
Edward
Juan4
Hi Edward,
The board of the motor burned out in the last blackout. I needed to replace the motor.  Thank you for your collaboration. Case closed - Damaged fan motor.
MelbaDT
Hey Juan4,
Got it and you're welcome! We're glad to hear that you've found the cause of your concern so you know how to resolve it. We'll go ahead then and lock this thread after a day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the Community.
Melba
