help had new condensing boiler fitted yesterday and now thermostat will not connect to heat link
TessV
my nest which is a 3rd gen was connected to my old boiler and worked fine. new condensing combined boiler fitted yesterday and nest thermostat will not connect tooth heat link
9 REPLIES 9
Frustratedddd
You could have a pairing issue here. Do you have lights on the Heat Link, if yes what colour?
Hi when I press the button for 10 seconds the yellow light goes off temporarily and it appears again as a yellow light. a quick press brings on 2 green lights and turns on the heating but have no control; over it. if I press it for about 20 seconds I get a blue blinking light which indicates it is ready to pair but it just won't connect and comes back with a h71 error
CristianC
Hi @TessV,
I'll do my best do get this resolved for you. What color is the LED on your Heat Link?
TessV
CristianC
Hey @TessV,
Thanks for the details. Let's try these steps:
1. Bring the display and base closer to the Heat Link and make sure the boiler is not in between the Heat Link and thermostat - only if possible.
2. Turn off the router and other WiFi or Bluetooth devices ( router, speakers, cordless phones, baby monitor, etc. ).
3. Select Replace Heat Link.
4. Enter the entry key ( do not confirm it yet ) — you can find it at the bottom side of the Heat Link, near the screw.
5. Restart the Heat Link twice by pressing on the Nest button for 30 seconds each time.
6. Confirm entry key.
Let me know how it goes.
TessV
Hi, I am waiting for a friend to help with following the instructions as I have a disability and can't get to my router get the heat link of yje wall to find the entry key
CristianC
Hello again. Just checking in. Do you still need my help?
TessV
thanks its all sorted now a friend did it for me
CristianC
Hello again. I'm happy to hear that it's been sorted. If anything comes up, let me know.
