my nest thermostat is locked, i forgot my pin and thermostat is offline
rchalupa
my internet stopped working yesterday. my grandson reset the access point, (verizon 5g home)
the access point reverted back to the default username and password. because of this the nest thermostat
lost its wifi connection, no app connectivity. when i went to reset the wifi info on the thermostat it is locked.
i cannot remember the 4 digit pin i need help to get this working.
Thank's
13 REPLIES 13
David_K
If you can't control it using the app anymore, you'll need to reset it using a computer.
  1. Connect the Nest Thermostat display via USB to a computer.
  2. Verify that the Nest Thermostat mounts (appears as an attached drive icon).
  • If the Nest drive will not mount: Restart the thermostat and the computer.
  • If the Nest drive still won't mount: Connect another device to the cable to see if it appears as an installed device.
  • If it doesn't appear, use a different cable/port/computer.
If the Nest drive is successfully showing up on your computer, can you see a technicalinfo.PLIST file? If you get this far let me know and I'll ask a community specialist to assist with next steps, as these can't be shared publicly in the community.
rchalupa
I can see the PLIST file when I connect the thermostat to my computer.
Hstomp
I am having the same issue and need help.
I can see the file technical info.plist
Can you help me?
rchalupa
I am still waiting for someone to contact me with the solution.
Hstomp
has it been over a week?
Thank you for replying
rchalupa
Yes, still waiting.
David_K
Good stuff. I've asked a specialist to review this topic and advise on next steps. Just so you know, it may take a short while for them to do that.
rchalupa
Thank’s for your help.
zoeuvre
@rchalupa, got it. We'd like to further check on this. Could you fill out this form and let me know once you're done?
I appreciate your help, @David_K
rchalupa
Hi Zoe,
I filled out the form and submitted it.
Thank’s
zoeuvre
We've received your form; thanks for filling it out. Please keep an eye on your email, as someone from our team will reach out to you to assist you more. If you have questions or concerns in the future, feel free to start a new thread, and we'll be happy to help.
rchalupa
Thank you for your help.
Rich
zoeuvre
Hello Rich,
You're welcome! We'll let our team know about this more assistance. Feel free to create a new one if you have more questions or have other concerns in the future.
