turn cooling from heating ??? How?
AlcalaDan65
Yes I still have a question on turning on colling from heat, and would like to TALK to someone directly, and NOT by messaging.. Is this possible???
11 REPLIES 11
I would like to know about what you wrote—“…turning on colling from heat…”. @AlcalaDan65 , What indeed is Colling and how can I get me some of that?
AC Cooling Wizard
I thought I set mine up correctly but when I switch to heat it only blows cool air. The wires look correct so I am wondering what I did wrong.
Any nest thermostat that you wish to change from heating mode to cooling mode, all you have to do is rotate to the heating symbol, or the cooling symbol and select it.
AC Cooling Wizard
When I do that nothing happens. It’s not turning the heat on. For example I turned it up to 72. It said it would take an hour. I left and came home in an hour and it was still 64. The fan was on but it never became heat.
What type of heating system do you have? Heat Pump, Gas Furnace?
AC Cooling Wizard
we have a gas unit.   and i am needing to be able to turn the heat off and the cooling on.
this is the information on our nest unit
s/n # 09AA01AF052203GJ
ITEM:  T3007ES
BAR CODE:  54448 00387
@AlcalaDan65 if your nest learning thermostat has been properly installed, you simply need to select the Mode symbol and choose the mode you want. Your possible mode choices are heat, cool, off. This is how you change the mode of your system.
Tap you Nest Learning Thermostat to wake it up. Rotate the dial ring until Mode is Highlighted. Press to select.
Rotate the ring to highlight Cool. Press to select
Thanks for reaching out. I hope you get the answer you're looking for. Please let us know if you still need help, for us to further assist  you.
Hello folks,
I'm checking back in — how's it going? I did find a helpful article on how to control your Nest Thermostat. Let us know if you still need help.
Hello everyone,
It has been a few days since the last reply, and we're going to lock the thread within 24 hours. If you have any questions, please feel free to create a new post.
