water control disappeared from nest app and controller
RichardW15
I've had my Nest Thermostat for a number of years and all has been good - heating and hot water all controlled by it
last week the water control heating or not has disappeared from the controller and my app
so i cant control any hot water ????
Head scratcher as its worked and nothing has changed so can anyone help ??
Frustratedddd
Are you in the UK with a Heat Link? I take it you have a system boiler?
Assuming you are.........Settings - Equipment - Pro Setup - System Boiler - Then follow the instructions BUT make sure you enable the on/off setting, then save. The icon will appear
