04-05-2022 09:05 AM
Do you know if there is a simple overview of how Google Nest works? (What is the function of the Google home account? How does it communicate with the mesh points? What is the overall infrastructure?
The help center recommends different steps without explaining why. It is important to know why we should take the step and what we are trying to achieve by it. That way, we can try to trouble shoot.
Just following the steps blindly and not knowing why we do it and what to expect is not helpful.
I need a simple overview of how it works, how does it connect to Google home? How does it communicate with the Wifi point? What is looking for? What is the overall infrastructure?
Is there such a thing? Does anyone know?
04-09-2022 06:18 AM
All of the devices in your Wifi network need to be associated with the same account and "home" or "room" in the Google Home app. Sounds like something hasn't gone quite right there and one or more of your devices are not in the right state to communicate properly with each other. I'd recommend resetting your router and all points to start fresh. You can do that by selecting Wi-Fi > Settings > Factory reset network > OK. That said, if some of your devices are not in the app, you will need to reset those using their physical reset button as well.
As for different reset steps, this help article explains resetting using the app vs the reset button on the device:
https://support.google.com/googlenest/answer/6246619
It's recommended that you use the app to reset your devices wherever possible and only use the factory reset button on the device if they aren't accessible in the app for whatever reason. That's because if you use the factory reset button on the device itself, your device(s) and network still appear in the app.
04-09-2022 06:18 AM
04-09-2022 08:47 AM
Thank you David, I tried for over 4 days and finally it worked.
Based on what you said, it looks like when I followed the instructions previously given to do a hard reset from the unit itself, it kept all the information on Google home and it did not allow me to move forward. So, after multiple tries, I am guessing somehow I cleared the memory in Google home and so I was able to restart everything successfully.
There should be a simple overview of how it works, what is the purpose for Google home, purpose for the associated email so people can actually trouble shoot logically when possible. However, there are just random suggestions that hopefully if you follow them they may eventually work or you can easily complicate a simple issue and never get it to work.
Thank you again and I appreciate your input.
04-09-2022 12:38 PM
@davidking, thanks for the help!
@Faram, I'm glad to hear that everything is working right now. Please let us know if you have other questions and concerns. We're here to help.
Edward
04-13-2022 04:04 PM
Hi Faram,
It's me again, I wanted to check back in to see if you have other questions and concerns. Feel free to let me know if you do.
Edward
04-15-2022 08:59 AM
Hi, everyone.
Thanks.
04-17-2022 10:50 AM
Since we have not received any more replies for quite some time, I will lock this thread now. Please feel free to create a new thread should you have some more questions or concerns in the near future and we'll be more than glad to help.
Edward
