Use router as an access point without ethernet connection
shijugm
Hi
I own a google nest wifi router and I need to add one more point to the mesh.
Can I use a nest wifi router on the mesh, instead of buying a google nest wifi access point ?
At this point, I cannot hardwire the second router but I plan to do that in the future.
Anonymous
Not applicable
Yes you can. 🙂 I do that too.
6 REPLIES 6
Anonymous
Not applicable
Thanks. That's amazing .
Jeff
Hi, shijugm.
It looks like you were able to get your answer on this, but I wanted to check in to make sure you were all set or to see if there's anything else you needed. If there's any more I can do, please let me know.
Thanks!
shijugm
Hi Jeff,
All set . You can close this thread.
Jeff
Awesome, shijugm. Thanks for letting me know. If you need anything else later, feel free to open a new thread.
90awdturbo
Even cooler, you'll actually get better speeds using a router as an access point over the actual access point devices.
