10-28-2022 05:53 AM
I have an odd problem that I can't figure out and wanted to see if anyone else has it. I noticed frequent dropping through only my hardwired LAN connection (not WiFi). The only commonality here is that the connections dropped were being routed through an unmanaged switch. The only way to re-connect is to cut power to the switch and unplug/replug the ethernet cable to the switch from the Google WiFi device. The first thing I tried was to replace all cabling (that didn't work). Then I tried to replace with a new switch, completely different model and different manufacturer (same exact problem occurs). I'm out of ideas here, but it HAS to be the Google WiFi device - it seems incredibly unlikely to be anything else. Any thoughts? Thanks!
10-28-2022 11:58 PM
I have 2 Trendnet unmanaged switches on my network between a Google Wifi and an access point and haven't had any drop issues on the same Gen 1 devices, hardwired or wireless. Below is my setup if it helps:
Other than WPA3, IPv6, and assigned device IPs, the Google Wifi main is set up basically factory.
10-29-2022 11:28 AM
We appreciate your help here, @PatrickP_Viking.
@kaledev, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
10-29-2022 11:29 AM
Hey no solution yet on my end. Still having issues with intermittent dropping of LAN connections through the switch.
10-30-2022 11:21 AM
@kaledev, I apologize for the inconvenience it has caused so far. At the moment, our team is still looking into this issue and I have no additional updates to share right now. I’ll continue checking in with the team and updating this thread as soon as I can.
Mel
11-02-2022 11:47 AM
11-04-2022 08:56 AM
Hey - I submitted, thanks.
11-04-2022 06:25 PM
Hey kaledev,
We got your form — thanks for filling it out. Our team will reach out to you via email to further assist you. Also, please be advised that this thread will be locked after 24 hours.
I appreciate the help, Mel.
Archie
a week ago
Any updates on this? I'm having the same issue with ethernet connections dropping through an unmanaged TP-Link switch.
a week ago
I never figured it out, I switched companies for mesh systems and left Google behind. No issues anymore.
Monday
Hey kaledev,
I'm sorry to see that you returned your Nest WiFi system, but I understand why you made that decision. As you have chosen to go with a different product, I did want to check in and see if there was anything else I could do for you at this time. If there's more I can do, let me know.
Jeff
Monday
For me no, but I think 'seedoubleyou' above is still having problems - I was just responding to them.
Tuesday
Got it. Thanks for the clarification, kaledev.
Hey seedoubleyou, are you still seeing the same issues as before? Have you tried any additional troubleshooting, and if so, have you seen any changes at all as a result? Let me know where things stand and I'll be happy to jump in and start helping.
Jeff
