Will a nest wifi pro router and point system work in France
Stef39
i am moving to France soon and I have just bought in the UK a nest wifi pro.
i was wondering if it will work in France as well as in the UK using some adaptors to plug them in the French power sockets or should I try to buy some power cable with French plugs.
hope that makes sence.
many thanks in advance.
Stéphane
GDog9
I can't see any reason why not. Although given the problems people are experiencing you may wish to wait until the faults have been fixed, or seek another solution. I used the Google WiFi in France, bought in the UK. No problems.
GDog9
Jeff
Hey Stef39,
The Nest WiFi Pro is fully functional in France. It's one of the currently supported regions and will work there as GDog9 mentioned. If you have any other questions about this, just let me know.
Jeff
Jhonleanmel
We appreciate your help here, @Jeff and @GDog9.
@Stef39, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
Jhonleanmel
Mel
