09-09-2022 04:05 PM
Does the Yale Lock not have door position detection? I have auto lock on x1 Min, and j left the door open to carry items inside. I then noticed it auto locks while still open which could be bad if I slam the door closed while the deadbolt is out.
09-13-2022 10:50 PM - edited 09-13-2022 10:52 PM
Hi Bpostel11,
Thanks for visiting the Community. I’m sorry to hear that and for the delayed response. Thanks for sharing that with us. It looks like your Nest x Yale lock isn’t calibrated. No worries, we’ll sort this out. A few questions: is your Nest app Home/Away assist settings on? Do you have any family members whom you’ve shared access with? Do you have an Android or iPhone? Is your lock’s deadbolt calibrated? Also, when did you first notice the issue?
If you have Auto-Lock on, always make sure to remember your pass code and make sure others who have access to your home memorize their pass code, so nobody accidentally gets locked out. For instance, you might be getting the mail and didn’t bring your phone with you.
When Auto-Lock is enabled, you can choose to have it automatically lock your door when you’re Home, Away, or both:
Try the steps here:
Let me know how it goes.
09-19-2022 07:51 PM
Hi, thanks for reaching out. There’s no issue with Home/Away or knowing how to turn off or on Auto Lock. It’s the fact that the door lock does not have Door Position Sensing. So Auto Lock is great and all, but only if you know your door is shut and locked.
09-19-2022 11:56 PM
Thanks for sharing that with us. Let’s have a better look — factory reset your Nest x Yale lock.
Here’s how:
Note: After you reset the lock, you must create a master pass code on the lock before you set it up with the Nest app.
09-20-2022 01:41 AM
what will this reset do? Are you saying that Auto Lock should only happen when the door is in the closed position? Does the Yale lock have Door Position Detection like other brands (August, Wyze)?
09-20-2022 06:27 PM
Good question! By default, the Nest × Yale Lock will not automatically lock itself, but you can use the Nest app to set your lock to automatically lock itself. You can choose how long your lock should wait before automatically locking, and you can have Auto-Lock on all the time or only when no one’s home. It might not be calibrated so performing a factory reset would re-calibrate your lock. You may also turn off and on the Auto-Lock timer setting to see if it works.
Try the steps here:
On the app home screen, tap Settings > select your lock > tap Volume > select Low or High.
Keep me posted.
09-20-2022 06:41 PM
Is there Door Position Detection?
Are you suggesting that calibrating the lock will fix “Auto Lock” to only function under its parameters and only when the door is closed?
09-21-2022 11:09 PM
Good question! Your Nest x Yale lock doesn’t have a motion sensor to determine whether it locks the door or not. The Auto-Lock feature uses a timer to lock the door after a predetermined time. You may turn off your lock’s Auto-Lock feature to avoid inconvenience. Instead use the One Touch Locking feature.
Here’s how:
Press the Yale button or hold your palm over the keypad to lock your home when you leave. If this doesn’t work, check the settings in the app:
Let us know if you have any other questions.
09-25-2022 03:05 PM
Checking back in — how's it going with your lock? Still need our help?
09-26-2022 05:00 PM
I just wanted to jump in here to make sure that you saw my response. Please let me know if you have any other questions or concerns as I will be locking this in 24 hours.
09-19-2022 07:43 PM
Hey Bpostel11,
Checking back in should you still have further questions here. Let us know by replying to this thread.
