Icon Settings on nest yale lock
Bo17
Hello, so I just installed a nest yale lock on our front door. Install was successful. However, I noticed that there is no settings icon on the keypad - just the numbers, the check icon and the back arrow. Is this new? I'm seeing that icon in the videos and photos of other nest yale locks...
11 REPLIES 11
Bo17
Anybody else have this issue?
Daddijimm
Yes
I apologize for my late response and thank you for all of your patience while waiting for a reply. I understand how frustrating your situation must be, and I would love to help however I can. I would suggest that you first Restart or Factory Reset the lock. It may clear out this issue and then you can try again.
Daddijimm
I’m not sure why you are not seeing my response.  I did restart.  The lock status showing in Google Home is not always consistent with lock.  The green light on my Google Connect stayed on as well.  Don’t know if that is a symptom of problem.
Just checking in to see if y'all need any further assistance as there has been a lapse in the thread activity.
SteveT1
We haven't heard any updates from you. Please let us know if you still need help as we will be locking this in 24 hours if we won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
Steve
SteveT1
HI there,
The gear icon that you are seeing on the Nest x Yale lock will only work when you have not set it up. Once set up, you can check your settings or other features in the Nest app.
Steve
janthadeus
Thanks for your help, Brad and Steve.
Checking in to see if you still need help with this. In case there are any follow up questions or comments. Please let me know if you need further assistance.
SteveT1
I apologize for the confusion. The lock icon on the Nest x Yale Lock is only useful when it's not added in the Nest app. Are you also having inconsistencies when using the Nest app?
You can check this article when your Nest × Yale Lock is disconnected or offline for more info.
Steve
Wow! Maybe I’m misunderstanding your post, but please explain the statement about not adding Nest x Yale to Nest App.  Is the only remote functionality from the Google Home App?
I’ve found the Nest App essential for the functionality of my Thermostat and doorbell camera (wired).  The inconsistencies are between Nest and Google Home apps.
janthadeus
Hi Daddijimm,
Just wanted to jump in here to make sure that you saw our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
