Missing setting icon on Yale Digital door Lock
Ish
Hey
Yale digital lock is working fine through the nest app and manually at the door screen! The only thing missing is the setting icon on the door Yale digital screen! For some reason it is missing and I can’t reset my pin code! Please advise
10 REPLIES 10
janthadeus
Hi Ish,
Thanks for visiting the Community. I’m sorry to hear that and for the delayed response. You have two options to change your pass code by performing a factory reset on your Nest x Yale lock or thru the Nest app.
Here’s how:
  1. On the Nest app home screen, tap Settings Nest settings icon.
  2. Tap Family & Guests family and guests icon.
  3. Tap You to change your own pass code.
  4. Tap Pass code.
    If you sign in with a Nest Account, you’ll enter your account password, minimize your phone’s keyboard, and press Continue.
  5. Enter a pass code, you’ll remember between 4 to 8 digits long.
    Note: If another person is using this pass code, a notification will pop-up to prompt you to Choose a different pass code. Pass code, must be unique so you can see who armed and disarmed your Guard or locked and unlocked your lock in History app history icon.
  6. Tap Show pass code to view the pass code.
  7. Tap Save. If you sign in with a Google Account, you’ll receive an email that your pass code has been changed.
Let me know how it goes.
Just checking in to see how the conversation is going, as there's been a lapse in activity on this thread.
janthadeus
We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you happen to have the same concern feel free to reach us out here or start a new thread.
Thanks for chiming in, Brad.
Ish
it's not resolved! The issue is that on the key lock the setting # is not showing and the problem still persisted!
janthadeus
Thanks for giving us an update. Did you get a chance to try the steps I shared? If so, how did it go?
janthadeus
Hi Ish,
Checking back in — how's it going with your Nest x Yale Lock? Still need our help?
Ish
hey JT, it's great that you are checking but i have no instructions to fix the problem! the setting icon is missing from the YALE key. I followed and reinstalled it and checked the wires but the problem persisted. what else?
janthadeus
Got it, thanks for your efforts here. Let’s have a better look — could you please factory reset your lock then let me know if that helps? Otherwise, we’ll be needing the help of Yale support to replace your Nest x Yale Lock as it may be defective.
janthadeus
It's me again. I want to make sure you're all good — how did the steps go?
janthadeus
Hi Ish,
I just wanted to jump in here to make sure that you saw my response. Please let me know if you have any other questions or concerns as I will be locking this in 24 hours.
