Nest Doorbell Battery
Ckandygreek
Purchased new nest doorbell battery version. Decided to have it hard-wired. Unfortunately the notification via your phone (if not at home) is nothing remarkable. With an iPhone/google there is NO away to increase volume level of the actual ring notification.
Google, please fix this. The notification via the google home app needs to be made more significant. The whole point of having this doorbell is to be made aware that someone is at your door if you are not home.
This is unacceptable
MrVacca
You can let the team directly know your suggestions through the feedback feature in the Google home app. If you open the app and then click on your avatar, you’ll see the feedback option.
Wondering if you still needed assistance with this issue? Please let me know!
GarrettDS
Have a great day,
Garrett DS
