12-13-2021 07:57 PM
For a while now, my lock would show offline and then online. I switched to the google nest wifi mesh. Everything is connected. The nest connect is connected to wifi with a good connection. The yale lock will not connect to the nest connect, the nest app sees the connect, but says to hold the button on the back of the lock until it flashes blue and the lock says ready. When I do that it flashes blue then just toggles privacy mode on and off. I have restarted the lock, by removing batteries for 20 seconds. I have also factory reset the lock twice and started over and it still won't connect.
12-22-2021 01:17 PM - edited 12-22-2021 01:23 PM
I have the solution here. You will need to create a 2.4Ghz Wifi guest network if you do not already have one. Make sure there is no security on it. Connect your Nest Connect to the guest network and when you have done that connect your phone to the same network. Use the options or settings menu in the Nest application to find your connect. Once you get the Nest Connect on to your guest network you can then begin to pair your lock to your nest connect. Follow the steps to pair you Lock through the nest app.
This worked for me and for whatever reason the Nest Connect does not seem to like being on WiFi networks with security. Once you get it connected and paired to you lock you can rejoin your secure network but I have seen random connection issues with it on the secure wifi. I am going to go back to the unsecured guest and see if its better,
12-15-2021 04:59 PM
Following because I'm having the exact same problem.
12-20-2021 10:47 PM
My lock won't connect either. Getting very frustrated.
12-21-2021 08:27 AM
12-21-2021 08:31 AM
Yes I still need help. My app still won't find/add the lock. My Nest Connect is there and working.
12-22-2021 07:10 AM
I spent 2 hours the other day with support and they couldn't get it fixed either. The problem to me looks like the step where you press the button on the back and wait for the lock to say it's ready. Now it just toggles privacy mode, even when you hold it down.
12-22-2021 08:59 AM
Have you tried to Factory Reset your lock? I understand this may be an inconvenience, but it could help fix this issue. Learn how to Factory Reset here.
12-22-2021 09:32 AM
Yup already did that too.
01-03-2022 09:15 AM
Just checking in to see if you still need assistance with this issue. It looks like some of you found a great workaround to the issue.
01-04-2022 08:22 AM
Hey Folks.
01-01-2022 10:42 AM
The factory reset worked, but what a PITA. There has to be an easier way? Thanks for blowing an hour of my life, Nest. Seriously, wtf!?
