05-30-2023 05:00 AM
For the past 2 years my Yale lock has worked fine. All of a sudden it disconnected from the nest connect. I have done a factory reset on the lock twice. The nest connect is working fine. I am on the same 2.4 WIFI and I have tried all the scenarios listed. It will not connect at all. What happened that all of a sudden I cannot get it to reconnect.
06-03-2023 02:37 PM
Hi MsSkydiver,
Thanks for reaching out to us, and I'm sorry to hear about the situation.
A few questions: Do you see any error code or message that appears on the app as you try to connect your Nest × Yale Lock to the WiFi? Was there any recent change on the WiFi network? Also, are there devices or appliances (such as baby monitors, microwaves, cordless phones, etc.) near the device you want to pair? Those devices could interfere with the Wi-Fi or Bluetooth signal.
06-06-2023 02:41 PM - edited 06-06-2023 03:49 PM
I wanted to check and see if you managed to see the questions I asked. Please let me know if you have any questions from here. I would be happy to assist and make sure you are good to go.
06-07-2023 02:44 PM
Hello MsSkydiver,
We haven't heard from you in a while, so we'll be locking this thread if there is no update within 24 hours. If you run into any more issues in the future, please feel free to create a new thread.
