12-01-2021 08:23 PM
During the setup process I would run into a problem getting the connect to properly setup, after a few hours with google chat, the solution we found was to create a second "home" and for some reason it was able to sync perfectly with that. Now my issue is that I have half my devices on my primary home and my nest connect with the yale locks on a second home. Is there someway to fix this so the connect will actually work with the primary home?
01-21-2022 10:32 AM
Sorry for the late response, but I wanted to drop in here to help.
I understand that this can be confusing but I definitely wanted to stop by and see how I could help.
Just wanted to double check to see if you were still needing help on this? If so, what troubleshooting steps have you tried?
I look forward to hearing from you.
Garrett DS
02-18-2022 10:48 AM
02-21-2022 11:29 AM
Hey Folks.
