05-10-2023 10:23 AM
I know there are multiple threads like this, but I've tried all the suggestions including creating a no password guest network. That made no difference. We had to change our wifi router and so everything had to be recreated. Google home devices all restarted fine on the new network. The nest connect sets up fine with the nest app and connection tests look good. But adding the door lock fails all the time. The key pad lights don't light up when the connect button on the lock is pressed. That doesn't seem to change when the Yale button is pressed to "wake it up". The Nest connect blue light flashes as if it's trying to connect but the process eventually times out with "something went wrong" . We've tried everything I can find including resetting the devices multiple times. What can anyone suggest?
05-13-2023 02:26 PM
Same issue, soon as I got the nest aware trial, it worked just fine
05-14-2023 11:14 AM - edited 05-14-2023 01:46 PM
Thanks, but I don't have any of the hardware, like bell, cameras etc, that Nest Aware supports. Just the door lock. Is that you case too?
Edit several hours later. I finally managed to get my x-Yale lock to connect. After multiple attempt at resetting it by removing the back, and holding the reset button while reinserting batteries it finally reset correctly. Had done this at least 5 times before the thing actually reset and the following setup proceeded as advertised. So I believe all my problems have been due to not getting the lock to reset completely before this.
