Nest secure vs other products question
zero014
Hello. I wanted to see the issue with Nest secure with regards to transfer to ADT.
Will the camera system and everything still work on the Nest app as normal? And it's just the nest secure alarm no longer working?
And does the ADT system sync with the rest of the google home? Or would that be a separate thing. For example would the ADT system work with the yale lock?
David_K
If you have a Nest Cam, not Dropcam, your cameras will continue to work as normal.
It's handled separately and depends what devices you have. Specifically for Nest x Yale Lock, that's not compatible with the ADT system, unfortunately.
Set up ADT with Google - Google Nest Help
Help for ADT customers - Google Nest Help
Juni
Thanks for the help here, davidking.
zero014, thanks for posting. I hope you've got the answer you're looking for. If you're still in need of assistance, please let us know, as we would be happy to answer any questions you may have.
Juni
Juni
I want to check if you have additional questions and concerns about your device. Let us know by updating this thread, and we're glad to assist you further.
Juni
Juni
Hello there,
Just checking in to make sure that you saw my responses. I'll be locking this thread if we don't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Juni
