10-28-2022 04:11 PM
2 Days ago my Nest x Yale began announcing "Passcode Doesn't Work Right Now" when entering my code. Lock will not accept a total of 3 out of 4 user codes I have installed. Only Master Code and User #2 currently work. I am the account owner. I have also been unable reconnect the lock to the Nest Connect following the last update.
11-02-2022 11:11 AM
Sorry to hear you're experiencing this, I would love to look into this further for you. If you haven't already, you can learn here how to factory reset your Yale lock, which may help to reset issues it may be having. Please let me know if you need further assistance.
11-05-2022 07:06 PM
I’m outta town until next Wednesday, then I’ll let y’all know how I fare.
11-05-2022 07:37 PM
Hey cconthecc,
Sure thing! Keep us posted.
11-08-2022 06:43 PM
Checking back in — did you get a chance to factory reset your lock? If so, how did it go? Let me know if you need more help.
11-05-2022 06:43 PM
I just wanted to jump in real fast to see if you saw Brad’s reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
I appreciate the help here, Brad.
11-13-2022 02:05 PM
All,
11-14-2022 02:41 PM
Thanks for giving us an update and we appreciate your efforts here. Let’s dig deeper into this — a few questions: what’s the status light of your Nest Connect? How far is your Nest x Yale Lock and Connect from the router? Are the batteries of your lock fresh and standard AA alkaline batteries? Also, what Wi-Fi frequency band do you try to connect to (2.4 GHz or 5 GHz)?
Here are some troubleshooting steps you can try:
Let me know how it goes.
11-15-2022 02:04 PM
Nest Connect Status light GREEN and 5’ from Yale Lock, Router Channel 2.4Ghz and 20’ from Nest Connect and Yale Lock, Brand new Duracells. All your proses steps were re-accomplished with negative results. Yale lock tries to connect to Nest devices, but fails. Thanks for the assist, JT.
11-16-2022 05:28 PM
Thanks for keeping me posted. Great troubleshooting so far, you can also give these steps a try:
Let us know if that helps.
11-16-2022 05:38 PM
You’ve got to be kidding!!! I’m not removing equipment that works, to install a piece of gear that used to work, but now fails. I’m done here.
I don’t need the automation portion of the lock that badly. My time is more valuable than this.
11-16-2022 05:53 PM
Understood, don't give up on us yet. We'd like to further check on this — could you fill out this form and let me know once you're done?
11-19-2022 06:35 PM
Hey cconthecc,
We haven't received your form. Were you able to fill it out? Do you still need help?
11-22-2022 07:22 PM
I'm checking back in to see if you are able to fill out the form. If not, please do so, so we can assist you further with your concern.
11-26-2022 01:53 PM
Hello there,
I haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you happen to have the same concern feel free to reach us out here or start a new thread.
