05-04-2024 12:23 PM
On troubleshooting to check the connection status of my nest connect it keeps going to yellow factory setting, even after I have pressed the button quickly to cancel the factory setting. Not able to get a green light.
05-07-2024 12:34 PM
Hello NancyG13,
That sounds frustrating, but it will certainly be my pleasure to help you with your Nest Connect. Here are some troubleshooting steps you can try to fix the yellow light issue with your Nest Connect and prevent accidental factory resets:
Button Press:
Power Cycle:
Best regards.
Helio.
