07-25-2022 07:58 AM
After having two Yale locks for two years the devices started to drain batteries in one day.
Both doors lock and unlock with no effort (smooth motion).
The Nest connects are about 6 feet away from each lock.
I did a factory reset on both units, this didn’t fix the problem.
Bought two more locks, batteries died in one day too.
I also have Google WiFi and Nest Thermostats around the house. Could someone help?
07-25-2022 12:59 PM
I am also struggling with batteries not lasting. I purchased my Nest x Yale lock about a month ago and have replaced batteries 3 times. I have reset and moved the connect to different places without any luck.
07-29-2022 11:00 AM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I'm terribly sorry to hear that you're having this issue, I understand how upsetting this could be, but I'm happy to assist you with this issue. If you are having issues with your batteries dying quickly, then I would suggest checking to make sure that the locks are sitting correctly as they could be not locking properly and that could be draining them quicker. Also, please make sure that you are not using rechargeable batteries, they must be AA Alkaline batteries.
07-29-2022 03:24 PM
Hi Brad- the lock opens and closes just fine. I’ve also used both Duracell and energizer max alkaline batteries without luck. Neither were rechargeable.
07-30-2022 05:05 PM
The batteries drain even with the new lock with the new batteries. This seems like a software issue since the hardware had been replaced including batteries. My guess it's over communicating with some devices on my network causing the excessive networking which drains the battery. Is there a way to pull some debug logs off of the device ?
08-01-2022 01:50 PM
Yale is sending a me a replacement lock. Seems they agree it is a software issue. I am hopeful this resolves the issue. No ETA on when I will receive the new lock however.
08-01-2022 01:59 PM
Did they mention anything about updating the software/firmware?
08-02-2022 08:42 AM
I am sorry to hear that most of you are still having issues with your batteries draining. I would suggest that you try contacting Support to see if this is a fault with your device, or if this is a bug. It sounds to me personally, like it could be a bug, but support should be able to assist you best.
08-12-2022 06:16 PM
I received a replacement today. Like the other one, it worked initially but hours later it no longer communicates with the nest app. The batteries will likely show as low very soon as well. I am running out of options.
08-14-2022 12:00 AM
Hi ryanbando22,
Thanks for following up. I'm sorry to hear that and I know the importance of having a 24/7 security with your Nest x Yale lock. I'm with you on this. Try to factory reset your Nest × Yale Lock then re add it to your Nest app. If the batteries would still drain quickly. You can reach out to the device manufacturer. You may call Yale support team at 1-866-475-2506 or email them at support@yalelock.com.
Let me know how it goes.
08-05-2022 08:43 AM
Best regard,
08-05-2022 09:33 AM
I am still waiting to receive a replacement.
08-05-2022 09:46 AM
Have you contacted Support about a replacement? Are you still within warranty? Please contact Support if you haven't already.
08-05-2022 10:34 AM
Yes. They approved A replacement 2 weeks ago I am just waiting.
08-05-2022 10:50 AM
I would check up with them or check your tracking information if you are still waiting. But ill keep the thread open for now.
08-08-2022 10:55 AM
Just checking in on this thread and the activity on it. We'll leave this topic open for another 24 hours in case there are any follow up questions or comments.
08-08-2022 12:10 PM
I am waiting a response from support on tracking info for the replacement. I don’t feel this should be closed until the issue is resolved.
08-08-2022 08:40 PM
They asked I called back end of week to see if there is any tracking info available.
08-12-2022 08:05 AM
08-12-2022 08:49 AM
Brad why does Google support close these threads before a resolution is achieved?
08-12-2022 08:51 AM
As Community Specialists, we occasionally do a bit of housekeeping to keep the conversations in our community fresh and relevant. This includes locking threads after a period of inactivity.
08-17-2022 03:16 PM
It's me again. Checking in to see if you still need help with this. In case there are any follow up questions or comments. Please let me know if you need further assistance.
08-01-2022 01:34 PM
Oh boy... I just got mine and installed it yesterday. I'm just replying here to stay abreast of this issue.
