Yale x Nest - frequently get "Nest Connect is using battery power", even when plugged into the wall
Eckless
Hi there - frequently get this "Nest Connect is using battery power" notification on our Nest x Yale lock. The Nest Connect is plugged into the wall. Sometimes with enough unplugging and replugging the notifcations will go away, but they then come back at a later date.
Any ideas?
7 REPLIES 7
mishaloralaylo1
yes facing the same. m also figuring out the solution
Eckless
Thank you, Brad - no worries, it was a weekend.
Yes, I do still need help with the issue (as does mishaloralaylo1, above!)
Hey folks.
Have y'all tried to restart/reset your Nest Connect? I have a great Troubleshooting Article that may help you out! Please check it out. Please let me know if you need further assistance.
Just checking in to see if you still need assistance with this issue.  We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
Hey Folks.
