04-15-2022 07:01 AM
My Yale x nest lock randomly stopped working. It wouldn't connect anymore. I attempted to factory reset the lock several times just as the instructions dictated. It will not reset. Regardless of how long I hold it. Any advice would be appreciated.
04-16-2022 09:43 PM
My (3 months ) Yale x nest lock stopped working user passcode (Working on master code only). I attempted to do factory reset multiple times its not even responding tried all format . Even I I hold it for a min - Its not working . Nest mesh was able to reset but the Yale lock is not responding and the blue light is not appearing even after a long press.
either blue light has to appear after a press to connect or factory reset need to work . Please let me know do I need to replace or need to update ?
04-18-2022 08:54 AM
I literally have the same issue. I too and stuck and need a reply. The hard reset doesn't work. I uninstalled the lock and now i can no longer controll it remotely and only the master works.
04-18-2022 12:22 PM
HI AYANTI,
It's resolved yesterday.. we have to try multiple time..
1. Remove the first and last battery
2.remove the screw
3. Then press the factory rest button . While pressing itself put the battery on both side
4. Try 2 or 3 time.. some what clicked me and all data got reset.
5. I started from resetting the master code
6. Also able to connect with app.
04-19-2022 06:27 PM
Thanks for reaching out. I appreciate the help @praveenraj85. Just checking in to see if the troubleshooting steps shared helped. You can check this article for detailed steps on how to do the Factory reset. If you have other questions and concerns, feel free to let me know.
Steve
04-24-2022 04:48 PM
It's me again. I wanted to check back in to see if you have other questions and concerns. Feel free to let me know.
Steve
04-30-2022 03:51 PM
We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you're still in need of assistance, feel free to start a new thread and we'll be happy to help.
Steve
05-01-2022 09:45 AM
Yes it resolved
