Smart Home Developer Forum
No posts to display.
Help Center
Welcome to the Smart Home Developer Forum!
Hey Nest Community, Welcome to our Smart Home Developer forum! This space is for developers to discuss, collaborate, and ask questions about their Smart Home integrations using Google Home Cloud-to-cloud, Local, or Matter APIs. Once you post, fellow ...
GoogleFAQ by Solutions Expert
  • 81359 Views
  • 29 kudos
Tapparelle stop
Ciao! Sull'app legrand c'è la possibilità di spingere "stop" per fermare le tapparelle ma questa funzione non c'è su google home. Compaiono solo "su e giù "...come posso fare? Grazie
Fehlermeldung HUE Aussensensor
Hallo CommunitySeit einem der letzten Updates von Google Home erscheint eine Fehlermeldung von meinem HUE Aussensensor.[current_Sensor_State_data.light_level.raw_value] wird vom Gerät [Sensor Süd - Default] nicht unterstütztDie Automation hat vor dem...
Mani1007 by Community Member
  • 79 Views
New phone won't allow home app info
Went from a working home app on pixel 7 using Android 16 beta to new pixel 10 pro with android 16 beta. I open and allow all permissions. But won't go past the eula/ google terms splash screen. The 'oo' choice is greyed out. Gone through all troubles...
537magspc by Community Member
  • 141 Views
Resolved! Time.Between condition not working
Hello When I use the script editor to create an automation routine, anything that has a time condition is not working. If I remove the time.between condition the routing runs. With it, nothing. But there is no error. What is wrong with this script? m...
aabruce by Community Member
  • 165 Views
