Green light problem
Siddharth1
Not working restart button and nothing.
Only show the two lights of middle.
and green light is stuck
Muddi
Hey Siddharth1,
To confirm, do you still need help with your device?
Muddi
28 REPLIES 28
David_K
Try these steps:
  1. Unplug the power cord from your speaker. Wait for 10 seconds. Plug it back in, and wait until all 4 lights on top illuminate.
  2. Repeat step 1, 10 more times for a complete total of 11 times. This is a key step, 11 times total.
  3. After you plug your speaker back in the final time, you'll need to wait a few moments for the device to reset. It will announce "Welcome to Google Home. To get started, download the Google Home app on a phone or tablet," to let you know that it’s ready for setup.
If you actually instead have the newer Google Nest Mini (2nd gen), at step 3, you will need to press the mute button on the back for at least 15 seconds and then it will reset.
I try it not working
David_K
Are you using the original power supply and adapter that came with it? You mentioned having tried a normal factory reset (the steps I shared above are a more advanced reset). Did you follow the exact steps below?
On the bottom of speaker, press and hold the factory reset button located below the power cord. Look for a circle etched into the base. After 5 seconds, your device will begin the factory reset process. Continue to hold for about 10 seconds more, until a sound confirms that the device is resetting.
If you actually have the 2nd gen model, you'll need to switch the mic off using the switch on the side of the speaker. The lights will turn orange. Then press and hold the center of the Nest Mini, where the lights are on top. After 5 seconds, your device will begin the factory reset process. Continue to hold for about 10 seconds more, until a sound confirms that the device is resetting.
You might also want to try plugging your speaker into a different power outlet just to test.
Restart button is not working and I am using original charger of Google home mini
Full device is stuck
David_K
Appreciate you trying those steps. I've asked a specialist to review this topic.
Dan_A
Hi Siddharth1,
We thank you for keeping in touch and following the steps above. May I know from where and when your Google Home Mini was bought?
Appreciate the help, davidking.
Dan
Siddharth1
Google home mini buy from Flipkart
Siddharth1
Buy Dete 2 October 2019
Muddi
Hey Siddharth1,
Chiming in, since we have exhausted the troubleshooting steps, the next thing to do is to replace your device. However, as much as we'd love to replace your device, it's no longer within our Limited Warranty. We know this is not the best answer that you're looking for, but let us know if you still have other questions otherwise, I'll be locking this after 24 hours.
Muddi
Siddharth1
I put a request
Muddi
To confirm, did you contact us via phone/chat support for the request? Could you tell us more about it?
Muddi
Siddharth1
Chat support I think
Muddi
Hey Siddharth1,
May I know the case ID so I can check the status of the case?
Muddi
Siddharth1
Sorry, I did not put my request correctly
Muddi
Could you tell us more about it? Are you able to contact our support team via chat or call?
Muddi
Muddi
Hey Siddharth1,
I'm just checking in to see if you still need help with your device.
Muddi
Siddharth1
  • Yes
Muddi
Hey Siddharth1,
Muddi
Marquezbon
Its better to dhow my son in a live cam
Marquezbon
But heneed most important to help my son because he suffer on dengue fever
Juni
Hello there,
Just checking in to make sure that you saw our responses. I'll be locking this thread if we don't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Juni
Juni
I just wanted to follow up to see if you still need our help. Please let us know, as we would be happy to answer any questions you may have.
Juni
Siddharth1
still not working my Google home mini
Juni
Hi Siddharth1,
Thanks for the reply. We regret to tell you that since your device is already out of warranty, we can no longer replace it. You might want to check this link for more info about our device's warranty.
Juni
Muddi
Hey Marquezbon,
Sorry to hear about your son. I hope that he gets well soon. Let us know if you need help with the Google Home/Nest devices, and the Community will be glad to further assist you.
Muddi
Muddi
It's been some time since this thread was updated. Does anyone here need assistance?
Muddi
Muddi
Hi Siddharth1,
We haven’t heard back, so I'll be locking this thread if we won't hear from you in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Muddi
