08-03-2022 07:00 PM
I'd like the Nest home hub to keep the weather screen but when it is dark at night the display switches from the weather display screen to a plain clock screen. I want to keep the weather screen. How can I do that?
Firmware version 6.20211109.1.3166240
08-09-2022 06:29 PM
@MplsCustomer, I appreciate all effort on helping out.
@Joruby43, just want to check if you have seen these settings on customizing your photo frame:
Google Home app:
Nest display:
If you have Voice Match enabled, you can also say “Hey Google, change Photo frame” to open Photo frame settings on your Nest display.
Hope this helps.
Princess
08-04-2022 08:44 AM
I wonder whether that's even possible. This recent thread on the same question seems to indicate that the Google Nest Support people have trouble even understanding the question: https://www.googlenestcommunity.com/t5/Speakers-and-Displays/How-do-I-make-the-clock-to-be-displayed...
08-09-2022 06:29 PM
Google Home app:
Nest display:
Hope this helps.
Princess
08-09-2022 06:54 PM
Hi, yes I know how to pick the frame I want. What I want to do is keep that choice. When I go to bed and the room is dark, the hub automatically switches to a plain clockface. I do not want that. I want the hub to keep the weather display screen I have chosen.
08-10-2022 04:58 PM
Hi Joruby43,
Thanks for clarifying.
Have you checked the display settings wherein you need to select "Show Clock" and make sure that Screen Timeout is turned off. Lastly, make sure to adjust the ambient settings from the Google Nest Hub display by swiping up the bottom of the screen and enabling the ambient settings for it to adjust to its environment.
Princess
08-10-2022 06:37 PM
Hi Princess all the settings are exactly as you mentioned:
I'm at a loss as to what to do next. I appreciate your help
08-11-2022 06:18 PM
Hi Joruby43,
Thanks for the update. Let's go ahead and perform a complete reset to your Google Nest Hub and see if it would make any changes on its behavior.
Keep me posted.
Princess
08-11-2022 07:36 PM
I did that once before but I will try it again over the weekend and let you know. Thanks!
08-12-2022 03:58 PM
Hi Joruby43,
Thanks for letting us know. I'll keep this thread open for few more days and will wait for your update.
Have a fun weekend!
Princess
08-15-2022 04:00 PM
Hi Joruby43,
Chiming in-- have you had the chance to try the steps? Let us know by responding this thread.
Princess
08-15-2022 04:20 PM
Hi Princess - I tried the hard reset and it is still doing the same thing. I guess there is no work around for it at this time. I'm ok with it for now. Maybe at some point there is be a fix.
Thanks for your help!
08-16-2022 03:32 PM
Hi Joruby43,
Thanks for trying the steps. Could you please attach some photos of the exact display that you're getting so we can check further? Also, kindly provide the cast firmware version of your Google Nest Hub?
To check which firmware version you're on, follow these steps:
Keep me posted.
Princess
08-19-2022 05:23 PM
Hi Joruby43,
We just want to check if you have seen our response posted above. Feel free to respond to this with the cast firmware version of your Google Nest Hub so we can forward this to our team.
Princess
08-20-2022 09:41 AM
Hi Princess firmware info
System firmware version: 6.20211109.1.3166240
Cast firmware: 1.60.305621
Country code: US
IP address: 192.168.0.77
I do not see an option to attach a photo to this message
08-20-2022 01:28 PM
Hello Joruby43,
Thanks for the additional information. We'd like to take a deeper look into this — could you fill out this form and let me know once you're done?
Kind regards,
Alex
08-23-2022 01:31 PM
Hey Joruby43,
Bumping in this thread to check if you're able to fill out the form.
Alex
08-23-2022 03:42 PM
I submitted the forms. Thanks!
08-23-2022 03:51 PM
Hey Joruby43,
We received your form — thanks for filling it out. Our team will reach out to you via email to further assist you. Also, please be advised that this thread will be locked after 24 hours.
Kind regards,
Alex
