06-09-2023 11:42 PM - edited 06-10-2023 08:41 AM
Problem:
FIXED: It appears to be fixed. I split my wifi and it worked after that, but it's not clear if it worked *because* of that. Either way, I'm happy to have the hub functional again.
My Nest Hub Max isn't working after factory reset - can't complete setup process, won't connect to wifi
So far I've restarted my phone, moved the hub next to the router, closed and open google home app, factory reset the hub multiple times, put the hub into recovery mode before resetting again, checked the password, and successfully set up other devices already.
I really hope the hub is not broken! I just moved and removed this from my google home by mistake, and then I had to factory reset it. Now it's not working. I'm hoping someone will have a suggestion that will get it working again.
06-10-2023 08:01 AM
What exactly happens during setup? Does the Home app detect your display? Do you see an error message in the app or on the display?
Try these steps:
Need help with setup? Troubleshoot common Google N… - Google Nest Community
Let us know how you get on!
06-10-2023 08:35 AM
It is working now, and I have not bricked my device it seems! I'm not sure what fixed it, though.
I would see an error in the app "There was a problem communicating with the Nest Hub Max".
It started looking like the hub was actually connecting to wifi and cutting out, based on the hub display. I eventually split my wifi into 2 distinctly named bands and connected the hub to the 2.4ghz. It worked, but I'm not sure if it was just time it needed or if the wifi split helped. Going to recombine wifi now, let's hope it still works.
06-10-2023 08:37 AM
Glad to hear it. That kind of error can often be an issue with the phone or tablet or a problem with your router settings. Sometimes a simple restart of the phone or tablet and/or the router can help!
06-14-2023 02:59 PM
Hi LiamRose,
As we've got our resolution here, I'm going to mark this thread as resolved. I'll be locking this thread if we don't hear back from you in 24 hours. Should that happen, feel free to create a new one if you have more questions or other concerns in the future.
Thanks for helping, davidking!
Dan
