GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,159 REPLIES 16,159
Oh, right. I didn't realise there was an outage. Will wait and see what happens.
verstell mal dein Datum in die Vergangenheit, also vor Sonntag und versuche ob Home dein Gerät erkennt. So ist es zumindest wieder in deinem Wlan und wird erkannt und gibt die Meldung wegen der Firmware an. Streamen geht aber trotzdem nicht. Das Gerät ist aber immerhin wieder "vorhanden". Datum wieder aktualisieren nicht vergessen
With the method I have shared you can use the Chromecast as usual.
@CookieHappyCat
Jag har samma problem med att konfigurera min chromecast till min tv. Den har fungerat jätte bra fram tills i söndags.  Är det fler som har samma problem ännu
Hannahpham
Please advise when it can be fixed as we really need it to work back as usual or can we have replacement While waiting
hank you
Valeiannots
Come mai Chromecast fino a ieri funzionava e oggi non mi trasmette?Ho provato a fare i vari reset consigliati ma niente anzi adesso non mi riesce più a configurare la tv, mi dice impossibile autenticare il dispositivo...come posso risolvere?
Look at my post below, it works correctly, you'll tell me.
@CookieHappyCat
C'è un problema generalizzato con i Chromecast e lo stanno sistemando, le indicazioni di Google sono di non resettare il device ma che provvederanno a dare le indicazioni per il ripristino anche per chi avesse resettato. Al momento non si sa ancora niente
Vangelis678
When are you going to fix this??? It's been almost a week....very poor customer experience... especially from a company like google!!!
graciela1973
No funciona, y como a muchos nos paso, el lunes lo resetee a fabrica.   Nos va a servir cuando solucionen el problema?
Ivanespichan
ya lo reinicie y ahora que perdi mi dispositivo
Elias_91
Ya van casi 3 días sin funcionar los Chromecast, cuánto van a tarde en solucionarlo? Si querían que actualicemos a dispositivos mas nuevos hubiesen avisado con tiempo que los volverían obsoletos.
Giorgia23
Buongiorno ho collegato chromcast alla televisione, procedo con l’app e al momento della connessione mi dice che è collegato e poi che si è verificato un errore perché nella privacy del mio telefono non ho attiva “ la rete locale” quando invece è fleggata. Mi potreste aiutare?
grazie
@CookieHappyCat
Oscar366
Buenas tardes cuando se solucionará el problema del cherome cast ya desde hace tiempo que no funciona no dan una respuesta al problema de como ni porque me siento estafado
Jf6
El problema chromecast continua, estamos esperando algo? Hay algo que podemos hacer? Se notificará algo? Porque medio?
Suerte a todos!
@CookieHappyCat
Morosolo25
Ciao, anch'io come molti da domenica non riesco più a collegare il mio chromecast, prima di comprare uno nuovo vorrei aspettare per vedere se c'è una soluzione.
Lo stesso anch'io, scoprire a posteriori che non bisognava fare reset ad impostazioni di fabbrica non è bello
Ckirkham1
The certification key that expired did not expire on earlier models.
Unless you fix this problem very soon a lot of people are going to walk away from Google in any form certainly for casting people are going to buy a fire stick from your competitor.
Ive just got in from Currys and done just that
Jayneslilgirl
Too late. Only way to view anything here is streaming through my Chromecasts around the house. I was going to upgrade them but not now. Tired of paying for the different platforms but being unable to watch anything... so just got in from buying Firesticks
Sprint46
Hola, el Chromecast no funciona, es imposible de autenticar con la aplicación.
Que demonios está pasando?
Por qué no está solucionado ya el problema?
Esto es ridículo.
Nanohananoha
iPhoneもAndroidからもですが、突然TVで動画などが見れなくなりました。  クロムキャストもWi-FiもiPhoneもアプリも全て全て正常です。再起動したり手を尽くしていますが 何故か信号がキャッチ出来ないとエラーが出て接続出来なくなりました。お手上げです。疲れてしまい どーする事もできません。🆘下さい!
何か障害が起きてるみたいですね。私も今週からいきなり見れなくなりました。初期化とかもしちゃったんですよね…見れるようになるのでしょうか。
コメントありがとうございます。
電源を入れ直したり  初期化、アプリの再ダウンロード  様々な方法を試したのですが改善されないので困ってまして…
Listo23y
Lo reinicie rápidamente y no va luego me entero que no había que reiniciarlo ,que pasara ahora
@CookieHappyCat
Sofia1012
I am trying to connect my Chromecast device, but I get the following message. What could it mean?
"Device authentication for your Chromecast was not successful'
I'm having the same problem with my chromecasts hurry up google and fix it
Same problem.  Apparently Chromecast firmware included an expriation date of 9 March 2025.  Any fix out there?  Thanks.
Change dáte your phone 2024
This is not a fix for the streaming Issue. It is online suitable to reconnect to your WLAN in case you made a reset.
Benzinchen
Hallo zusammen,
seit dem letzten Wochenende funktioniert unser Cromecast nicht mehr.
Wir haben ein älteres Fernsehmodell und der Cromecast ist die einzige Möglichkeit bei uns zu streamen. Wir lange wird es denn dauern, bis Google das Problem behoben hat? Denn wir bezahlen ja derzeit monatlich Amazon Prime und Disney+ und können beides nicht nutzen.
du wirst hier keine ante bekommen. Google hält sich komplett bedeckt, weil sie genau wissen, was der Fehler ist und weil es immens schwer ist, da die meisten Nutzer ihr Gerät schon auf die Werkseinstellungen zurück gesetzt haben.  Davon wird jetzt aber ja abgeraten, obwohl auf der Hilfsseite ja nachwievor dies als erster Schritt empfohlen wird, wenn ein Problem besteht. Ein Nutzer auf Reddit, der sehr viel Zeit und Engagement in die Sache steckt und verschiedene Anleitungen zur Problembehebung gibt, schreibt als Zeitspanne auf jeden Fall von einer Woche. Alle findet man auf deutsch eigentlich gar keine Hilfe, schon gar nicht von Google
Mira2
I try to recounting the chromecast put I can’t and received this message
Mira TV may be set up, but we could not communicate with it from your iPhone. Make sure that you have enabled local network access in your iPhone’s privacy settings. Then try again.
Please solve this issue
thank you
MPL-Consulting
I’ve already done a factory reset bevor I read this. Can you please help me?
Same here, I have removed it from home 😞 I thought it would be easily setup as usual.  I've been using it for many years.   But this time. I can't authenticate to set it up.  Let me know if you find any answers to fix it back up
