GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,152 REPLIES 16,152
Anonymous
Not applicable
i first unpluuged and reconnected my device and update began, before that nada
Ya lo restableci de fabrica
Randy9
no me deja actualizar ya he echo varios intentos y nada
Guys my Chromecast is back online!!! Thanks a million!!!
Randy9
Cómo hizo
What if it is not plugged in? I just now saw this, am at work, and it’s not plugged in.
Bonjour,
Quelle sera la solution proposée si une réinitialisation usine a été effectuée, et que nous rencontrons toujours un problème, comme vous évoquez, nous empêchant de reconfigurer notre chromecast ?
Merci pour votre retour.
Bien cordialement.
Safe to do resets after the fix?
What happens if it is not plugged in? I am just now seeing this. This should be relayed to all costumers…I shouldn’t have to go on here to find it.
Speriamo dopo tutta questa attesa di ricevere un buono sconto per un futuro acquisto
Ok just unplugged it to take the power off and left it for a minute then put it back into the usb and it’s now downing a update….
Llevo 2 días intentando  conectar chromecast  y no hay forma,por favor  solucionando lo antes posible,gracias
Yay! I'm getting the update just now. 😊
g222740
Can you explain how you're receiving the update? I did the factory reset last night for both devices and still no update currently. I left both devices connected to my TV in on mode. I'm happy for u tho
Fixed yesterday evening. My Chromecast audio is working OK now.
ok now back working after power off and on. Scotland U.K.
Prossimi giorni....avvisare via mail gli utenti,  è  troppo difficile?
MFMCL
My Chromecast audio is OK now.
that is the one that was the best thing
So need to keep device on and connected to wi-fi 24 hours ? Please clarify . Thanks
My device got updated just few min ago. Now it working as before. I am from India (Timezone +5:30).
**bleep** you
Praticamente uma semana e nada de resolver, tá parecendo obra do governo
Tienen un tiempo estimado para solucionar el problema de los Chromecast?
I WAS TOLD TO FACTORY RESET THE FIRST DAY!! I AM STILL WITHOUT SERVICE!!
7 DAYS NOW!!! THIS IS BULLS**T!!!
VERY VERY UNHAPPY
Still not working here in Denmark
Thank you for getting me back up and running, you should try to trouble shoot quicker or be better prepared next time but grateful it's back on. Thanks 🙏🏻
Anonymous
Not applicable
Hi
Now Chromecast is working again, hooray 🙂
Thank you so much! //Mobbom42
It says mine is not connected to the net what do I do to connect it. It can't update if it's not connected
Same here
I did the workaround fix first & that worked. (I had already done the factory reset)
Set you clock on your phone (in settings/general..) to 03/07/2025 , then unplug replug in your cc, & go to your Google home app & install the device as new. Enter your Wi-Fi . You once connected to WiFi your cc will update & the Google fix will work. Go back to your phone & change the date/ time back. It worked for me. Good luck !
Hello Team, my Chromecast 1. Gen works perfectly after your update and does it‘s job. Thank you for the quick fix! You are doing awesome!! 😘
Please do as early as possible..
Well, none of my devices are showing up. This sucks - come on, Google, do better! And give us some real help. This is no way to treat your customers
I cannot connect my TV chromecast.  What is taking so long?
malheureusement j'ai réinitialisé ( usine) mon chromecast  2éme génération pouvez vous m'envoyer un mail pour m'indiquer comment reconfigurer mon appareil ; merci d'avance SALUTATIONS
Anonymous
Not applicable
When will the problem be fixed??
Leia os comentários...
It's working again after an update of Google automatically.
For those that factory reset their device. I set my android phone manually to an earlier date than last sunday...i chose march 6th. Then I turned on my TV and chromecast and used google home to try and configure it...IT WORKED...you will be able to link it to your home wifi and then it did an update and long story short...IT'S WORKING AGAIN! Just remember to reset your phone to the current date and time.
