GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,161 REPLIES 16,161
Exactly the same. The link doesnt help.
Jonato
Não consigo configurar meu Chromecast pq c chega em no ponto de ler o código que aparece na tv, vem uma msg no celular dizendo "não é possível autenticar seu Chromecast, acesse obrigado link da Google, porém não tem nada que ajude a reinstalar.
Phillal
Have recently connected fine, but when trying to cast all of a sudden it said something about chrome cast not being a trusted device, (or maybe it was the phone not being trusted device). I then did a reset of the chromecast and now I get this error when trying to connect. “Master bedroom TV may be set up, but we could not communicate with it from your iPhone.”
Does the chromecast device need software updates and how can I check this if I’m not able to connect?
I already tried everything from this thread:
https://www.googlenestcommunity.com/t5/Streaming/Can-t-communicate-between-chromecast-and-iPhone/m-p...
ReseCy
Same thing is happening to me and I've tried every piece of advice I could find to fix it. I've had mine for years without issues and they're clearly still connecting to the internet because the screen is still showing on the TV. My sister is going to bring her phone over to see if hers will connect.
MitchJ
Could you put this information, or any information at all, on the actual troubleshooting page? It has a nice 'select your issue' option but provides literally no information on the topic aside from a 'was this helpful' button. I've already factory reset my device due to this issue and hope it can be fixed soon.
Maybeth
Hola reinicie mi dispositivo ya que como no funcionaba pensé que era algún error por favor necesito asesoría para volver activar mi dispositivo, agradecida
Parece un fallo global, un error con los certificados de seguridad solo para la 2nd Gen curiosamenta la 1st Gen funciona 😕
Alhrik
Well oops.  I have already factory reset the Chromecast that suddenly stopped working, since this was the fix for many issues in the past. Looking forward to a fix.
Neb32
When troubleshooting, first thing is reboot. Second is factory reset. Too late. A notification in the home app would have been helpful. What's my options now that my devices have been factory reset?
Allan_t
Need som help regarding Chromecast
Have been using them for years now but within 2 days at least 4 have stopped working.
I have tried to factory reset two of them but during the setup is says connecter but only to to can't connect to Chromecast.
Have also tried to restart the router. Nothing seems to work....this simply can't be an coincidence.
Derik64
Its a bug. The certificate is expired and google is working on the problem. Same issue with my 3 Chromecast Audios.
Google made a statement and this is a known google issue. No one with a 2nd gen can use them right now. This link explains in more detail and if you like me reset your device to fix it, there is advice on how to remedy that issue. Good Luck!
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
Bas3
Hier de workaround/fix om je chromecast v2 weer te laten werken, voor de Nederlanders onder ons, die Android gebruiken:
https://www.googlenestcommunity.com/t5/Streaming/Hoe-je-de-ChromeCast-2e-Editie-weer-werkend-krijgt/...
Aebav
Of course MOST of us have factory reseted the device.
What should we do??
Momo4
I already factory reset because that is what google told me to for troubleshooting. I then found out it was an error affecting everyone. What can I do? This is a rude way to try to get people to buy the new version.
Geen1
Please let me know how to reset it up as I reset the chromecast (using Android to Smart Tv, from Google Home app, thanks
JDL1103
I have 3 Chromecast devices that are not working since yesterday afternoon. I rebooted one and did not work. All show offline in Home app. I factory reset one and can't reconnect to Home app as it indicates "Can't Authenticate". My account shows 2 cases being worked on but no info as to status to get my 3 devices up and running again for streaming of video & audio.
Please advise ASAP as many of home's entertainment is Google operated w/devices & HUB.
DLHOUGHTON
Come on Google this isn't good enough. You tell us 3 hours ago not to reset our Chromecast yet online that's the first thing it tells you to do. If mine is broken from doing a reset I expect a whole new Chromecast in the mail thanks
What message appears in your screen? I did everything already.
I know. It really sucks the Lama’s ass. I’ve tried just about everything.. No Google recommendations from me!
Is something going on with chrome cast as mines has stopped working too..reset and now wont setup again
Abz05
Same problem here aparently it’s a problem world wide with chromecast
Yo también lo restableci de fabrica, ya que es lo primero que te dije Google que debes hacer. Espero que Google se encargue de resolver este desastre y que mi Chromecast funcione, pese a haberlo reseteado.
Bas3
Abz05
Exactly the same here
Carsten-1002
I can't get chromecast to connect to router. It's been working fine for years but suddenly it stops connecting. I've tried turning chromecast and router on and off. Please help in advance, thanks Carsten.
The chrome cast is not working world wide for the 2nd generation
I have the same problem. it was working fine for years but from yesterday it suddenly stopped.
Jk3ebk
Unable to cast with chrome cast is there any fix yet?
Sanya
I’ve reset my chromecast, updated my phone, updated my apps, made sure my local network access is on, and I still receive this message:
Living room tv may be set up, but we could not communicate with it from your iPhone. Make sure that you have enabled local network access in your privacy settings and try again.
Local network access is definitely on. i don’t know how else to solve this issue. My phone used to connect no problem. Chrome cast light is white, both devices on same wifi
Jensa
I face the Same issue.
Three daYs ago Chromecast was Not reachable (YouTube App Said - maxbe Firmware)
But even factory reset does Not Help.
Wirh Android i am Not able to reachable WLAN selection tab. Wirh iPhone i rrach until WLAN should bei connected but then Progress Stopps.
Hoe that there will BE Help Outside
Pica77
Si yo desde anoche no me funciona, espero que no  hayan quedados obsoletos, el mío es generación 3
Lauritalab
Estoy en la misma. Me dice algo de la versión de firmare desactualizado
Klacasse1968
How much longer?? It's been 7+ hrs
Abz05
I have already done a felactory reset trying to fix the issue is that going to be bad?
cawauk
Same issue here. Logging a message so Google can extrapolate an rough number of how many users they've impacted.
Olby10
Hello? 24hrs here.... should you say something or is just a trick to make us bought a new device?
anglophile
How, exactly, will we be informed if we factory reset the Chromecast.
I am sure many many people did so because we were following the Help screen list of what to do to resolve the issue.
Hurte
Estoy de vacaciones y contaba con este dispositivo, den una respuesta a los usuarios o empiecen a regalar Google TV para todos
Adav
So you guys wait a full day after JillG tells us to factory reset... to tell us to NOT factory reset... Too late.
