GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
Have we got any solutions?
Same here. We couldn't authenticate your Chromecast
This error from 10th March 2025
I have been struggling to fix the problem with Chromecast since yesterday, until I found this community link and saw it is a universal problem. I tried updating the Firmware, and further, it was giving an authentication issue. Kindly share the solution if anyone has received from Google or anywhere.
Cheers.! (JP)
What is happening? Why no reply from Google?
Yes, same here, was working yesterday. Stopped working. Device showing as off line in Home App. Did standard troubleshooting. Factory reset results in not able to authenticate message
Still having the same problem.
I am also getting the same error
I am also getting the same problem from yesterday dated 09032025
Driving me demented but I now know it’s not my own chrome cast that is the problem even though it is old .
Would be polite for Google to at least explain and rectify asap
This is so bad. Such a big company and no fix yet since yesterday
Same problem since yesterday.  Factory reset didn't help.  Cannot connect. Cannot add again to Google home.
From India, same issue
Same problem, done all troubleshooting including reset, router config, old version of google home setup, nothing works
Germany, same issue . 2 different messages
1. Couldn't authenticate Chromecast
2. communication with Chromecast not successfull
Go to your phones settings and manually set the date to before the 9th and it'll work. Whatever update was set from the 9th won't let ya cast but before it on the phone is fine.
Helios98
Yes, I set my phone to 03072025 and it let me connect it.
Yes it worked
Same issue. Wish i found this before factory resetting my chromecast.  What did they do?
Same problem here, but I have 2 Chromecasts 2nd Generation and 4th Generation, and only have a problem with the 2nd Gen one. What about everyone else? Perhaps this is specific to an older gen.
Same problem. I hope they fix it asap
why have Google not put a message out there to explain the problem and how long before it is fixed???
Same issue here from Greece!
Same also in Germany
I have the same issue with Gen2.
Casting is not working for more than 24 hours.
After factory reset I receive Chromecast cant authenticae both on Andorid and Iphone OS.
google suc...
Hey  same here with my chromecast and Android. Any solution yet?
Same!! Very annoying and disappointing
I am having the same problem......ca
Just adding to the list of users affected. Was fine until yesterday. Reset does not solve
I have try with IOS and Android and showing the same error! Hopefully they can fix the issue!! I even talk with my provider to check my modem router settings and is set properly. and checking this topic , its seems to be is a general issue with these devices .
Also having this exact message popped up, used it last week no issues, tried Sunday to connect and nothing! Factory reset, everything on troubleshooting, different devices, no luck. Tried again tonight after leaving it unplugged for an hour, and still nothing.
And I thought its only me. 2 days ago was everything fine and I have checked all the possible reasons just to find out that I have only wasted my time.
I'm still seeing the error message as well. Worked on it a bit yesterday, then did a factory reset. Just tried again, and it's still not working.
Same issue, did factory reset can't authenticate.
I've been experiencing this same issue since yesterday. I literally thought the same as everyone else:
It was just me
My Chromecast was old and outdated
I broke something...
Glad to see I was wrong on all accounts but would LOVE to get answers.
Hey Google! What is going on with Chromecast??
Same here are you reading this Google
I found a response from GoogleNestTeam Admin on another thread that was posted 8 hours ago. GoogleNestTeam response can be found here.  It says the following:
I have the same problem starting on Sunday March 9th.
Same! It worked just fine on Saturday. On Sunday it said to update firmware and today (Monday) i did a factory reset and still nothing.
My Chromecast won't connect either or authenticate Good to know I'm not the only one but very sad for Google not good if I need to I'll buy another product definitely not Google
Same here. All three devices in the house dropped at the same time in this timeframe. No suggested fixes worked.
