Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-12-2025 01:26 AM
You are 100% responsible for people resetting their device and this will take you out of the hardware scene if not fixed in a day or two. Play the "we do not support" card and watch your hardware become old in stock.
03-12-2025 01:34 AM
well, since there was no communication I have reset my Chromecast several times and now cannot reconnect to my WiFi. If you cannot solve the problem please let me know what gadget to buy to replace my Chromecast that will work properly and work at the same standard as before
03-12-2025 01:38 AM
Unfortunately, I followed your help pages which told me to hit the factory reset button (according to comments on Facebook and Reddit, I'm not the only one)...hope there will a fix for this too!
03-12-2025 01:39 AM
do you trust googlevil to store your data? cancel google drive before you lost really important stuff
03-12-2025 01:42 AM
Dear fiends in misfortune, I'm starting to suspect that google is making fun of us, and that it doesn't want to solve this situation at all. The Chromecast certificate has expired, we have to throw it away and change supplier forever!!
03-12-2025 01:49 AM
Mai usato Drive
03-12-2025 01:44 AM
Darn. Really wish I'd seen this info before I did the normal first step of factory resetting the device.
Hopefully you can fix this soon.
Was it some sort of update that went wrong? My devices were working totally fine until 2 days ago.
03-12-2025 01:50 AM
Manually setting date on my phone prior to March 9th 2025 worked for me. However I was one of many who factory reset, so I hope the fix Google comes back with works!
03-12-2025 01:52 AM
I have the same problem from Mar 9,2025.
Also already factory reset my device.
03-12-2025 01:53 AM
So a fix is coming, great. But for how long will they be usable? 😳
03-12-2025 01:56 AM - edited 03-12-2025 01:56 AM
I did not reset my chromecast, but I did delete it from my House in Google Home. On my TV I do still see the ambient background (Google Images screensaver) and time, but I cannot re-add the chromecast to my House 🤷 I don't get an error message. When it searches for chromecasts it just doesn't show up, so nothing to add (except a chromecast from neighbours every now and then, lol). Is there something I can do? I tried the thing with changing my phone's date back, but it didn't make a difference.
I'm just so glad I still have a dvd player and bluetooth speaker...
03-12-2025 01:58 AM
I did the exact same thing. Best to wait for an official solution I guess.
03-12-2025 02:06 AM
and cancel google drive
03-12-2025 02:56 AM
Do you want my copy of Shrek dvd?
03-12-2025 05:14 AM
03-12-2025 02:04 AM
Hi, there, am very surprised my chrome cast works very well in my office, not in my private room neither the guest room ....
Regards
Sylvia Bourdon
03-12-2025 02:55 AM
I need to investigate your private room urgently
03-12-2025 02:12 AM
I shall rename your company Doogle and remove all the dead wood
03-12-2025 02:23 AM
I need to know how to fix this after a factory reset
03-12-2025 02:48 AM
Hi, it's not yet fixed but there is a workaround available over here for casting again:
Android Authority posted this workaround
03-12-2025 03:50 AM
This only half worked whilst I could set up chromecast and have the wallpaper I still get an error when I try to cast anything
03-12-2025 04:29 AM
Same here!
03-15-2025 05:06 PM
me too
03-12-2025 04:28 AM
This worked so I could set it back up again, however, won’t cast anything, says firmware it out of date
03-12-2025 02:54 AM
Bin it buy a Tesla
03-12-2025 02:40 AM
When is it going to work again ???
03-12-2025 02:53 AM
We'll be back from mars sooner
03-12-2025 02:40 AM
Hoping if I comment, I'll get notifed of the fix once possible.
03-12-2025 02:52 AM
No fix yet
03-12-2025 02:43 AM
Hello my 2 Chromecasts on my 2 tv don t work anymore as cast.but the google screen still there .I reboot one of the 2 and now it doesn't appear anymore.please help me thank you
03-12-2025 02:52 AM
Have you tried going to the local theatre perhaps or the pub?
03-12-2025 02:48 AM
Salve ho azionato il pulsante di resetta della crome cast ma nulla sarà possibile riutilizzare?
03-12-2025 02:57 AM
Itsa broka
03-12-2025 02:58 AM
The delay in resolving this issue is completely unacceptable. Three days and counting is just not good enough for a billion dollar Tech company like Google. Now seriously considering a migration to Amazon Fire stick and Alexa home automation devices.
03-12-2025 03:05 AM
Hi, what should I do if I already did the reset of my chromecast?
Thanks
03-12-2025 05:36 AM
Data cellulare al 7 marzo
03-12-2025 03:11 AM
Any update ??? since Monday now ... maybe you can use AI ?😁
03-12-2025 03:26 AM
Is there any news? I made a reset already. So please tell me what I have to do now.
Thanks
03-12-2025 03:29 AM
Anyone here actually realise that there are several fixes to get your Chromecast....
1* reconnected to the WiFi after a hard reset
2* regain the ability to cast again for Android devices/Chrome browsers
3* change internal debug settings to enable a form of 'root access' and bypass authentication altogether
Do your research people, show initiative and stop sooking on forums wanting attention. I found a solution within 2 minutes of first noticing the issue 2 days ago!!
03-12-2025 04:17 AM - edited 03-12-2025 04:28 AM
Yes, I can confirm that the workarounds you mentioned do indeed restore Gen2 casting from Android devices and Chrome browser (sorry, iPhone users). Had mine back up 'n running by Monday morning. Not perfect, but for those who are impatient (and tech-savvy enough), it's a viable option until Google issues a proper certificate fix.
https://www.reddit.com/r/Chromecast/comments/1j7lhrs/comment/mgy1a88/
https://mensfeld.pl/2025/03/bringing-your-chromecast-back/#how-to-fix-it
