GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,162 REPLIES 16,162
ESTO ESTAN RESPONDIENDO DESDE GOOGLE.
Hola,
Gracias por ponerte en contacto con nosotros. Hemos identificado un problema con los dispositivos Chromecast. Nuestro equipo de ingenieros está trabajando en ello para solucionarlo lo antes posible.
Por el momento, te recomendamos que no realices un restablecimiento de datos de fábrica en tu Chromecast.
Te agradecemos desde ya por tu paciencia.
(Espero que lo resuelvan)
Are we going to get any response from Google? as their customer service didn’t help
Yo estoy exactamente igual con los tres dispositivos , solo pude reiniciar uno ,.pero no conecta con Youtube. Los otros me dicen no se puede autentificar
Same issue with chromecast Gen-2
From Pakistan 🇵🇰
Same here in Newfoundland, 2 gen seems not to work anymore
I received this from Google this morning:
"Hello there, thanks for reaching out, we're sorry to hear that you are having some issues with your Chromecast. We're aware of an emerging issue impacting Chromecast 2nd gen and Chromecast Audio devices and are working on a fix. Do not factory reset your device - we will keep you all updated when the fix rolls out. If you have already factory reset your device, we will provide instructions to set your device back up as soon as possible. Thank you for your patience."
Also encounter the same problem. Though I know now it's about a certificate date problem. I hope this wil be resolved quickly.
Same problem, Chromecast audios stop working altogether. Have the whole house tied into it with google hubs. This will be th reason to ditch the whole google home. No use now
Same issue for me and I tried to restart it using the bottom and I cannot
Mine has suffered exactly the same. Not only one Chromecast, but TWO.
The other Chromecast is working ok.
I reset my wifi, restore factory settings on Chromecast and the WiFi modem. Changed password, reinstall the Home app.
NOTHING HAS WORKED.
Es una sorpresa desagradable, llegar a casa y querer tu Chromecast y no se pueda hacer, solo por una actualización que Google se le ocurrió. De verdad se pasan.
Same here - my Chromecast Audio has stopped working. Done Factory reset, and all I get now is "we couldnt authenticate your device - contact support".   So its affecting THOUSANDS of people - but no official word of what is going on?
Is old Chromecast device is no longer working?
I am facing same problem since morning. It was working fine yesterday.
I hope they fix this as soon as possible,
Exactly the same problem here in Brazil. Yesterday it stopped working, I reseted everything and the message is that it can't authenticate.
Google????????????????????????????????????????????????? Any communication?
For those who are still looking for an answer to the chromecast device problem.
Google knows about the problem. Got to do with a certificate that ended on 9 march.
They are looking for a fix.
If you did a factory reset... you can fix that. Atleast, it worked for me.
I set my android telephone date on an earlier date and installed chromecast. BUT ... it still doesn't work. So we have to wait with a lot of patience 😉
Same issue with 2nd gen  Chromecast.  No problem with 3rd generation.  Software and firmware up to date.  Reset had no effect.  It worked fine yesterday.  Discovered about 8vam PDT
Alguien pudo solucionar este problema?? Mi Chromecast aún no funciona. Gracias
Alguien pudo solucionar este problema?? Mi Chromecast sigue sin funcionar.
Muchas gracias
In Argentina we have the same fault, a disgrace, I hope they give a solution and do not damage the devices remotely to steal from people. A disgrace.
Desde Argentina tenemos la misma Falla, una vergüenza, espero den una solución y no dañen los dispositivos a distancia para robarle a la gente. Una vergüenza.
Meu Chrome cast 2 não está autenticando , o que está acontecendo,  não está funcionando na tv.
A Catalunya passa el mateix des de ahir.
Si heu fet reset hi ha una solució per reinstal·lar Crhomecast (Encara que no funcionarà fins que Google ho repari):
Canvieu manualment la data del vostre smartphone, posar una data antiga, per exemple tres dies abans d'avui, així podreu tornar a configurar Chromecast des de Home.
Despres recordeu de posar la data automàtica en el vostre smartphone.
Salut a tothom.
Ormai sono passate più di 24 ore con soluzioni pari a zero da parte di Google😭
Google should announce a timeline so we know whether we need to wait days or months for a fix...
Mine is also same problem, help me out.
Same here.  Since last night.  Very suddenly....none of the 3 casting devices seem to work anymore.
There's authentication issues with my  Chromecast  device starting 9th March.
UK user..
Same here
Se necesita una solucion, ya que tengo 3 dispositivos de 2da generación, y si esto pasa con sus dispositivos posiblemente el de 3era generacion y el de 4ta que tengo tambien dejen de funcionar a la larga.. Asi ya no
Guess what...
Same crap here. Everything was fine and all of the sudden my Chromecast stopped working. Thank you Google. I tried everything. Got really frustrated and ended up with nothing...
Même problème en France.
Après une réinitialisation d'usine impossible de se connecter.
Après modification de la date du téléphone au 1 mars. J'ai pu le faire remonter dans Google home.
Mais il est toujours hors connexion.
Et je ne peux pas non plus le renommer.
Merci pour toutes les informations de la communauté.
Merci à Google de résoudre le problème le plus rapidement possible. Et d'informer les ces équipes de support .
I got the same problem, really disappointed, i even rebooted from factory that it seem to make the situation even WORST. 😞
stesso errore anche per me da ieri 9 marzo.
Possibile che google non dica nulla?
Same here in  UK. Can't find a solution.
Stessa cosa sta succedendo a me da ieri sera domenica 9 marzo 2025
What's the solution?
It's so frustrating
Im gonna purchase an Amazon firestick  to fix this issue
