Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-14-2025 11:23 AM
THANKYOU GOOGLE
CHROMECAST 2ND GEN HAS UPDATED ITSELF AND WORKING 💯
CHEERS!!!!
03-14-2025 11:23 AM
Thank you for noticing problem & trying to fix! HOW will you tell us, what do do? Through this Forum page or an email? Thanks again.
03-14-2025 11:25 AM
Read the status update at the top of this page. Google started rolling out a firmware update fix yesterday.
If you are one of the many who have already done a factory reset, you'll need to do this procedure in order to receive the update:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
03-14-2025 11:24 AM
Prime casts but Netflix cannot find the device? Any ideas of why?
03-14-2025 11:23 AM
Hooray it's back
03-14-2025 06:38 AM
What if u have already had make a reset on your Chrome cast Audio.
Do you slove this issue to?
03-14-2025 03:52 PM
For the audio device I assume the issue is the same do this fix
03-14-2025 11:28 AM
I had m’y chromecast factory reset!
I did the change of date trick, this put the device back online, streaming was still not working.
Now your fix has been deployed and the chromecast is now fully operational.
thanks
03-14-2025 11:26 AM
Lo habia restablecido a la configuracion de fabrica . No había visto la noticia que NO había que configurarlo de fabrica.
03-14-2025 11:30 AM
03-14-2025 11:28 AM
BI=♧
03-14-2025 11:28 AM
Still nothing? Almost one week and nothing.... I have restored because I never would have thought that the problemas would be from Google...... This is very bad jocke...
03-14-2025 11:31 AM
I can't believe that Google still hasn't pinned this information to the top of this page, for all the thousands of folks like yourself who have done a factory reset.
In any case, it's an easy fix. Just do this:
03-14-2025 11:29 AM
Fate presto
03-14-2025 11:30 AM
First my Chromecasts came online in the Home app but I still couldn't cast. After several restarts of Chromecast, phone and network router I could finally cast again! 🤘😎
03-14-2025 11:31 AM
The first thing I did when it stopped working was trying to factory reset, as the troubleshooting instructions directed. Please provide instructions for factory reset devices as well.
03-14-2025 12:39 PM
Take a mobile and set date back to 2024. Start Home app and setup the chromecast. It will work, will update and connect
03-14-2025 11:33 AM
Please, I reset my device because I didn’t have this information.
03-14-2025 11:44 AM
I can't believe that Google hasn't pinned this information to the top of this page, for all the thousands of folks who have aleeady done a factory reset.
In any case, it's a fairly easy fix. Just do this:
03-14-2025 03:50 PM
03-14-2025 11:30 AM
Olá, não foi solicitado nada pra mim,e como devo proceder?
03-14-2025 03:49 PM
I am sorry this response is in English but try this fix:
03-14-2025 11:34 AM
Como ficou sabendo quando o meu receberá a atualização? Está dando erro na senha wi-fi,e não foi mudada a senha,já fiz de tudo pra fazer funcionar o aparelho,mas não mexi nas configurações originais de fabrica. Não volta a funcionar!!!!
03-14-2025 03:47 PM
I am sorry this response is in English, but look at this fix:
03-14-2025 11:35 AM
Hello think I factory reset my device. What do I do now?
03-14-2025 11:39 AM
I can't believe that Google hasn't pinned this information to the top of this page, for all the folks who have done a factory reset.
03-14-2025 02:13 PM
At this point people should be able to factory reset it again and the Chromecast should work after completing the setup process, just did this with my Gen 2 Chromecast and now it's working as intended.
03-14-2025 11:35 AM
Had reset then disconnected mine before realising it was a general issue and now it won't reconnect to home. Please post advice when you get the fix sorted for that too.
03-14-2025 11:38 AM
I can't believe that Google still hasn't pinned this information to the top of this page, for all the thousands of folks who have done a factory reset.
03-14-2025 11:55 AM
Change the date back to 8th March set google home
close all apps
change the date back to current
it will connect
and thanks me later
I just did mine
03-14-2025 07:28 AM
Chromecast can’t sync with wifi
03-14-2025 11:56 AM
It's working
03-14-2025 11:36 AM
Android Hisense with second gen white remote. Only key that works is on off screen freezes after google shop announce clock works goes to ambient original and Google remote doesn't work. Is this a feature or bug!
03-14-2025 11:37 AM
Both of my Chromecast audio device did receive the update and are working again!
I had to reboot them in order to change their name and see other device information after the update.
03-14-2025 11:37 AM
To get your Home app working again after factory reset, put the date March 1 in your phone, start Home and connect the device and subsequently put the date on automatic again. Worked great for my 2nd gen Chromecast.
03-14-2025 11:37 AM
Count was blocked for no reason on to add to streaming to apps lockout
03-14-2025 11:39 AM
Meu Chromecast 2 ainda continua sem funcionar ☹️
03-14-2025 11:39 AM
And for those of us who have reset their device, how long do we have to wait?
03-14-2025 11:43 AM
I can't believe that Google hasn't pinned this information to the top of this page, for all the thousands of folks who have done a factory reset.
03-14-2025 02:25 PM
I've actually tried this but my Google home still doesn't pick up my chromecast.
