GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,162 REPLIES 16,162
Hey! I still cannot connect my iPhone to Chromecast, I settled up all the steps and all I can see is an error:
“Si bien es posible que se haya configurado Ático, no pudimos comunicarnos con ese dispositivo desde tu iPhone. Asegúrate de haber habilitado el acceso a la red local en la configuración de privacidad de tu iPhone. Luego, vuelve a intentarlo.”
The configuration is ok and I’ve been trying to do it all over again several times. So, which steps I must follow or how long should I wait for this to be resolved?
I find the process of obtaining a job at Google quite challenging. It seems that the company typically requires candidates to have 5 to 12 years of experience. I would appreciate clarification on the rationale behind this requirement, especially considering the capabilities of some specialists who may struggle to facilitate communication between devices within the same company. Perhaps it would be beneficial to consider hiring junior professionals as they can bring fresh perspectives and innovative ideas to the team.
Please let me know I did a factory reset and still getting unable to authenticate message when trying to follow your reset
I’m unable to run the updated Google Home App as my IPad now can’t support IoS 16 as it’s older - which is required to run the updated app and fix the chromecast streaming issue. What can be done about this as I just followed the instructions to do the factory reset.
I have already made factory reset to the chromecast, so i am waiting you to solve the proplem.
And try to connect with us in arabic please
Just checked : there's no such version on the play store for the HOME app...
How will I be notifed about solution? My 2nd gen. Chromecast doesn't connect. Please contact to me and explain what to do. It isn't comfortable for My 2 years son watching from smartphone.
Hi - I am still unable to activate my Chrome Cast.
I did perform the factory reset however I just tried to set up the chrome cast again with the up to date google home app but it keeps saying something went wrong and does not connect to the wifi.
Tem uma previsão para normalizar?
But my device is gone from Google home. I cannot check the firmware version nor can I install it again…
I still can't connect. I did a factory reset and the latest version of Google home currently on app store isn't the version needed to fix the issue. Please advise
Hola, he descargado para Android y para Ios la úlima versión y me sigue dando error no conecta no encuentra el Chromecast.
Por favor, me pueden dar las indicaciones para poder conectar al Chromecast.
Gracias
HI mother I don't want him to come to the hospital 🏥 I get
Holy cow... this impacted MILLIONS of people.  In the meantime, I hooked up my old Apple TV with optical output.  I'd forgotten how seamlessly it connects to iOS without the glitch that Chromecast has with iOS.
I no longer need my Chromecast Audio.  You actually helped me "Upgrade" to stuff I already own.
First off, thanks to the team who fixed this issue my 2nd gen Chromecast. It's now working and I love using it.
Sadly though, it now has a new (perhaps resurface of an old bug) problem where even though I have YouTube premium on my phone (working as expected with no ads), when send to Chromecast, I get advertisements).
It wasn't doing this when it was working before your latest fix.
Is this the new normal?. I hope not ..
Sadly though
Igg
Update on my previous post:
Not sure why, but as of now there are no ads appearing when viewing YouTube premium on Chromecast.
All is good. Thank you Google!
Hi can you tell me how long will this take to fix this problem thank you
amrzizo
For those who want to run Chromecast, the solution is to watch this video.
https://youtu.be/QlTSKPNLTS8?si=j1rchr5rh2ksEdUe
https://github.com/sdex/ActivityManager/releases
com.google.android.gms.cast.settings.CastSettingsCollapsingDebugAction
Subij2025
Magot
Muchas Gracias, no habla mucho espanole, pero is muy “helpful”. I never used my phone to cast before, and wonder why this is necessario ahora? Mucho gracias, otra vez!
G89
Está tendo notícias q o Chromecast voltou o meu até agora nada , preciso de uma solução.
Cente
la solución es demandar judicialmente
Domejmar
Ya se me instaló la actualización! Encendí la tele y salió automáticamente. En la app de Google Home me aparecía en gris la TV como si no estuviera conectada, pero no importó.
Virginie
Bonjour,
Depuis hier, j'essaye de caster un film. J'utilise l'application Google home et une chromecast branchée à mon téléviseur. De l'application Google home, ma chromecast est bien détectée, c'est lorsque je fais connexion à la chromecast que mon téléphone passe automatiquement en 5G et de ce fait, n'aboutit pas à la connexion puisqu'il faut que ça passe par le Wi-Fi. J'ai donc un message d'erreur qui apparaît « impossible de communiquer avec votre chromecast". J'ai tenté de l'obliger à passer par le Wi-Fi en enlevant les données mobiles mais rien n'y fait, il ne passe pas par le Wi-Fi donc le message d'erreur est identique. Lorsqu'il essaie de se connecter, j'ai un message en fond qui me dit "qu'il est possible que mon téléphone se déconnecte du Wi-Fi lors de la configuration" c'est exactement ce qu'il se passe mais il n'indique pas la procédure qui permettrait à mon téléphone de ne pas se déconnecter du Wi-Fi. Je suis bien en Wi-Fi. Je me suis déjà connectée à cette chromecast il y a plusieurs mois. J'ai eu Free au téléphone qui me dit qu'il n'y a pas de souci de son côté. Je suis connectée à d'autres appareils en Wi-Fi sans problème. Avez-vous une idée pour débloquer ma situation ?
Un grand merci pour votre aide !
Virginie
Karl62
Anche a me fa la stessa cosa..ha sempre funzionato da un po' di tempo mi dà problemi. Le ho provate di tutte..ma nulla..non risolvo più
Goedemorgen 👋🏻
Zet de datum van je telefoon/tablet manueel naar bv 08 maart en start dan de installatie van je Chromecast. Tadaaa...
Perpedal
No earlier warning about reset to factory ? Warning came wednesday ???
5 days now !
Come on Google !
I can't believe that Google still hasn't pinned this information to the top of this page, for all the thousands of folks who have done a factory reset.
In any case, it's an easy fix. Just do this:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Anonymous
Not applicable
The link isn't accessible.
Fyi to all: If you performed a factory reset, you can still re-attach it to your "home". This will allow you to receive the new firmware with the updated CA certificate installed. Here's how: Using your device (e.g.: Android phone or whatever you have the Home App on), change the date to March 1st. Then add the new device to your home per normal. It will find it as a new device and it will connect to the network and internet again. Then it will get the new firmware when it rolls out. You're welcome 🙂
Thank you so much, I did this and it fixed 2 of my Chromecasts.
Mauricio64
Não funciona,é agora que avisam pra não redefinir 😡
If you have done a factory reset, then you just have to do this fairly simple procedure in order to receive the update:
Wrx94
My chromecast came back to life today. I didn't do anything, just left it alone. It updated itself.
SharlaB
Is the problem fixed? Cause I cant connect. You wrote this monday, and It's friday now?
try again today
Read the pinned status update at the top of this page. Google started rolling out a firmware update fix yesterday.
If you have already done a factory reset, then you'll have to do this procedure in order to receive the update:
Nest75
it is a silent fix, you will only know if you use Google home and try again
jwsalim02
Hi, all my  Google Chromecasts are fixed today. I had to go to GoogleHome to reset and update my devices. I did not factory reset mine when the problem started. Thank you for solving and please do not let this kind of issue ever happen again.
Poncesantiago1
Hello
Do you have any solution to this problem?
If you have done a factory reset, then you'll have to do this fairly simple procedure in order to receive the update:
